What is a normal oil consumption for LS1?
The engine has stock (and original) internals.
I usually drive it home to office: 2x 15 miles on country roads.
I use a 0W40 synthetic oil.
I have a catck can after the PCV: it traps some oil but never so much as what I have to add.
In winter it needs 1/4 every 1500 miles: is that still OK for how I use this car or is it too much?
Thanks
Stefano
The more I drive above 3K RPM the more oil I tend to use, as well as fuel...
During my short trips the engine reach a normal operating temperature only after 2/3 of the driving time.
I usually shift at 2000 - 3000 rpm and every day the engine goes up to 4000 rpm a couple of time.
Is that the cause of my oil consumption?
So right now it's a simple NA and is consuming all that oil
Maybe it's because of my short trips... is there something i can check?
Using a quart in 1000 miles is definitely not OK...One between oil changes, I could see, but not 3 quarts having to be added between changes...that can't be OK.
Is it possible that I'm usig so much oil because of the short trips I usually do?
http://www.mikenorrismotorsports.com/
I purposely used clear tubing, instead of the black that came with kit...that way I can see if any oil is making it to intake or not.
In summer it's just oil, in winter it's a mix water-oil. it's about 50 - 100 ml every time I fill the fuel tank.
I don't think the quart I loose every 1500 miles is 100% trapped in the catch can. I guess about 20% of it.
