Comp Cams XE-R Questions
112 lsa 4 degrees of advance? Will it work well on a stock engine that amy be getting longtubes in the near future? How is the idle? I am not the most knowledgeable about cams: read moron, not quite, but mostly uninformed. Thanks.
for a M6 i'd get the 112, but for a auto i would stick with a 114. I have the comp 224/224 .563 114 and its great in upper rpms. I just havent fixed my warm stalling issues yet. Idle sounds awesome though a open cutout, but with it capped it sounds like stock. You will more than likely have to raise your idle a tad, and do some other tweaks to make your car idle and run better
I don't run at the track (yet), or push the car past 5500 RPMS very often ( usually doesn't break 5000, no need; ricers). I really am looking for something with a nice kick in the pants. Cam is local so I am invetigating a little (.567 lift is what I am told). Thanks
<small>[ February 03, 2003, 04:22 PM: Message edited by: SSCamaro99_3 ]</small>
If you got the same specs the two cams would be identical
In a nutshell any "Xtreme energy" cam for us would be an XE-R
hope this helps
and i am almost positive the xe-r lobes start at .581". the .56x lift is the xe lobes. imho they wont make a power difference in a mild build up motor.
is this travis' cam by the way? just wondering.
<strong> there is a misconception out there. XE & XE-R are the same grind, ramp rate also. They are both Xtreme eenergy cams. However the XE is a flat tappit cam and the XE-R is a hydraulic roller cam.
hope this helps </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Im sorry but this info is not right, XE and XER are both roller. XER is more aggressive ramps and requires more spring pressure. I have literature right from Comp. about this.
hope this helps </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">FALSE <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
XE and XE-R are both hydraulic roller, like the LS1 is from the factory.
I've spoken with 3 different people on different occasions that said the exact same thing
By the way, the R in XE-R stands for roller
after you talk to comp let me know what they told you
John
later,
Steve
Steve
<strong> EXACTLY, XE stands for xtreme energy "XE"
xtreme energy roller "XE-R"
here is the number for those who want it
1-800-999-0853
John </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Wrong. XE and XE-R are both hydraulic roller lobe profiles, XE-R are faster ramps and subsequently have about 4 degrees less advertised duration at an equivelent .050" duration.
if the r stood for roller cams and rockers, then stock ls1 motors would have a real problem using them right? <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
