Help on a cam change
Old Dec 10, 2007 | 04:50 PM
chevy0128's Avatar
Default Help on a cam change
well i am pretty new to the world of ls1's but i have read alot about cams and heard alot of good things. I really only have intake, Paceseters LT ory catback and i was curious if i cam would be ok to do next? or is there other things i need to do first? About how much can i get a cam and instal for? thanks
Old Dec 10, 2007 | 05:01 PM
sroach20's Avatar
cams run around $200 used and up, then the springs and pushrods run around $350. use this to install it yourself: http://www.ls1howto.com/index.php?article=23
Old Dec 10, 2007 | 05:13 PM
chevy0128's Avatar
see i no i will f**k it up. I barely manage to do headers... so for about 2k or 2500 i could get the cam and install because i no install is expensice as hell
Old Dec 10, 2007 | 05:34 PM
FadedSS's Avatar
do you have an a4 or 6speed? if an a4 get a stall first...
Old Dec 10, 2007 | 05:55 PM
sroach20's Avatar
if you posted your location you could probably get some shops to quote you a price.
Old Dec 10, 2007 | 06:03 PM
eallanboggs's Avatar
If you're faking the dumb act you need to zip it when you go into a shop for a price or you may end up paying a lot more than you expected. If you're not faking I feel sorry for you. Just be sure to bring a jar of vasoline when you pay the bill or it may end up hurting more than your pocket.
Old Dec 10, 2007 | 08:35 PM
chevy0128's Avatar
ha well im not a dumbass i wont just pay any price that someone will tell me for an install. I just dont no that much about internals engine i just got my ls1 5-10k miles ago. Before this i had a bmw which i just like for luxary. switched and went for speed so i am stil pretty new
Old Dec 11, 2007 | 01:55 PM
DMONEY06's Avatar
just try and do it yourself whats the worst that could happen
Old Dec 11, 2007 | 03:26 PM
DMoney06 wants to know "the worst that could happen"? Now there's a loaded question that I don't think he chevy0128 wants to hear the answer to. With all of the nightmare installs one could imagine and some that are beyond imagination the possibilities of what could go wrong are endless. Even with all of the good tutorials on the web some people still manage to screw it up. Tutorials are good if you know how to follow instructions. You should also have the tools needed for the job and I don't just mean handtools. You need basic mechanical skills to be able to realize when you're about to make a mistake. The people who have these abilities stop and ask a question on LS1Tech.com when they realize they are on the verge of screwing something up. The others break off rocker bolts, strip crank threads, smack pistons into valves bending pushrods and valves. What's "the worst that could happen"? A lot.
