synthetic vs conventional oil
Old Dec 11, 2007 | 05:12 AM
DMONEY06's Avatar
Default synthetic vs conventional oil
ok i was told that once you use synthetic oil you cant switch back to conventional because it would leak through the valve seals is this true or can you switch back to conventional with no problem??? thnx
Old Dec 11, 2007 | 06:53 AM
COD02SS's Avatar
You can switch back. No worries.
Old Dec 11, 2007 | 11:24 AM
smokintiresz28's Avatar
i heard the same but is it fact or myth
Old Dec 11, 2007 | 11:50 AM
sroach20's Avatar
its a myth! you can switch back and forth all you want.
Old Dec 11, 2007 | 12:18 PM
C5LS6's Avatar
Wow, there is actually a myth like that out there?? Wow!
Old Dec 11, 2007 | 12:48 PM
dbuie's Avatar
I heard that whenever I was 22 and got my first new car. Now I'm 39. Also, I have always been told to not switch to synthetic on a high mileage (>100K) car. Synthetic is thinner and old cars are more prone to leak.
Old Dec 11, 2007 | 12:55 PM
teke184's Avatar
i was told by someone once that the when synthetic first came available, there was some concerns over the compatibility between them with conventional.
i'm sure it was something more of a guidline at first...but has long since been corrected.
if it were true...don't you think there would be a warning on the labels? can you imagine the legal backlash that would come from mixing the two if it were indeed a problem?
if you could sue for having too hot of a coffee, you could sue for a new engine cause the oil was not compatible.
Old Dec 11, 2007 | 12:58 PM
COD02SS's Avatar
It's as bad as "Don't use synthetic to break in an engine"
Old Dec 11, 2007 | 01:06 PM
bombloader's Avatar
I wouldn't switch TO syn on a high mileage engine. I will leak through the old gaskets.
Old Dec 11, 2007 | 01:19 PM
DMONEY06's Avatar
thnx for the info im probably gonnna switch back to conventional oil
Old Dec 11, 2007 | 05:57 PM
JedWele's Avatar
I have run synthetic in all my vehicles some with very high miles, never had a oil leak from sythetic.
Old Dec 11, 2007 | 05:58 PM
DirtyBird222's Avatar
man only if everyone knew what lube techs did at dealerships lol. the past two dealerships i've worked at the dumbasses mix and match synthetic and conventional 1) becaue they usually forget 2) so they can change their oil for free by stealing the customers oil or 3) they just feel like being dipshits.
really i dont think it makes a difference, ive never had any problems when i've had to change my oil and been low on cash and had to use conventional. you should be fine
Old Dec 11, 2007 | 06:02 PM
sroach20's Avatar
the dealers arent the only ones that do that!
Old Dec 11, 2007 | 10:31 PM
ch3089's Avatar
Dave from Rehr and Morrison race engines wrote an article about synthetics in certian cars and the viscosity that he uses and recommends!!!
Old Dec 13, 2007 | 11:06 AM
bombloader's Avatar
Sounds like good reading. Do you have the link?
