Ms4 GUYs come in!
well i'm running the ms4, stock ls6 heads, stock ls6 intake, stock tb, slp lt's through cutouts, ls7 clutch, and moser 12 bolt with 3.73's and finally made a clean pass to an 11.9@116. That was on a 26x11.50 mt et street running 11 psi, that is one reason my mph isn't that high. 60' was a 1.71 but bogging off the line from a 5000 rpm clutch dump. I'm about to swap the gears out for either 4.10's or 4.30's. Ain't made up my mind yet. I should be able to turn low 1.6's or high 1.5's to the short mark, but the 3.73's just ain't workin for me. I will have some new times when the track opens again. I'm guessing it will be close to the mid 11's around 119 to 120. When i mean it bogged, i mean it dropped 2-2500 rpm with no tire spin. Its a great cam imho although i don't dd it, i have and its not bad as long as you have a good tune. oh and 1/8 was a 7.7 @ 92.
shoulda raised the tire pressure to 15, then tried again... if still bog, raise until it doesnt bog, but spins. then lower by 1.
yes the lift is high at the time i used it i had ls6 stg 1 heads . now this time around im thinking of useing trick flow ill post what ever i deside 2 use
hahahaha^^^^^^
Back to subject, I have it loved it then everything went bad, After about 6 months car got weak, prob not the cam, but I feel Tsp has better grinds to be installed. Went 13.45 at 112mph with a heak soaked car(drove straight from amarillo to the staging lanes in Idalou), and no clutch above 5000rpm and missing 3rd hahaha. Oh this was my daily driver. ( i think i hurt a rod (replace your rod bolts), which bent a valve slightly). /oh yeah then I sprayed the ****, and then some magic item found it's way into the the #4 cyl.
hahahaha^^^^^^
#33
hahahaha^^^^^^
HAHAHAHAHHAAHAHAHAHAHA
Sorry man, its late and i have been drinking, but that was some funny ****. At least your a good sport about it. Some people would have given up!
Was your car tuned for both the cam and the spray? Not only that, did you have slicks on? 13.5 sounds pretty off for the cam and nitrous!
Just Curious!!
#34
hahahaha^^^^^^
looks like your car put down good number, but i bet it was because of a stock rear and so on.
thats funny ****. and like i said, i pulled on a head and cam LS1 6 speed.... i think its mostly in the tune.. not going to say any names cough(LSsomeone dave)
anyways
#39
Well I witnessed it first hand. I dont know why the outcome was like this but I speak the truth. The 2 MS4 cars were an LS1 Goat and a WS6, The MS3 and heads car was a Z28. If it would have went much farther than a 1/4 mile race the MS3 car would have probly won. By the way it wasnt because of traction issues or anything either.
