Ms4 GUYs come in!
here is a link to the video. http://videos.streetfire.net/video/f...ad00c3588a.htm
This is when i first put it together and got all the bugs worked out. Best all motor was 11.60@121. Before anyone says anything about the long crazy burnout i was pissed because i couldnt get the mt drag radials to hook. You can see it spin like hell.
as your on the gas.my combo 347,ported t/b,ported maf,ls6 intake,42lbs,ported 317 headsw/2.02/1.6,3800 stall,3.73.my truck weights 3650lbs and
some spray.
trucks are suppose to have torque down low and the ms4 has anything BUT...
3.73 gears with spray at the take off and a 3800 stall, sounds good to me! Streetable yet Vicious at the track!
Probly be best with 150 shot off the line.
I plan on getting the MS4, and I have been doing a bit of research myself lately. I am trying to get the best combo for the cam without spending the extra cost of flycutting the pistons. This cam really is big, and to take its full potential, you will really need a good intake like a FAST 90/90, and a good set of heads. The PRC stage 1 LS6 heads will be a bit better than the stockers, but with how the cam wants to really breath, it will undoubtingly be more benefitial with flycutting the pistons and going with some much larger heads like you are thinking.
I am also considering just going with a MS3 instead, and then going with some bigger heads to make up the power difference and still avoid flycutting, but I am still trying to figure out if the MS3 with a killer set of heads will give me more power than a MS4 with a stage 1 set of LS6 PRC heads would.
