918 spring life
Old Jun 26, 2003 | 11:58 AM
thechef's Avatar
Moderator
Default 918 spring life
hey guys i got 918s non stripe springs on my car
i have used them with my 2 cams and are on the car currently with my second cam and i have 16k on the springs as i drive the car everyday
how long are you guys going before you swap to new springs???
Old Jun 26, 2003 | 12:02 PM
StreetStalkerZ's Avatar
Default Re: 918 spring life
I have roughly 20K-23K on my 918s and over 200 track passes along with some street races with no problems. I'll switch mine out in a few months for some new 918s.
Old Jun 26, 2003 | 12:03 PM
9T9BlueTA's Avatar
I was planning on changing mine at 20k intervals. I dont go to the track much or live in the redline.
Old Jun 26, 2003 | 06:07 PM
Cal's Avatar
Cal
The guys at TR say 918s will theoretically last indefinetly on the the cams they sell . . . so I think it depends on the specs of your cam.
Old Jun 26, 2003 | 07:15 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
I have a B1 cam. I plan on going at least 40K before changing them. The car hardly sees any track time....
Old Jun 26, 2003 | 07:19 PM
98sspullin'em's Avatar
it all depends on the spec of you cam, the bigger, the shorter theyll last, thats what ive been told
Old Jun 26, 2003 | 07:36 PM
RPM WS6's Avatar
I would think that ramp rates are probably one of the most important factors to take into account. Faster ramp = lots more wear on valvesprings....
Old Jun 26, 2003 | 08:32 PM
gillbot's Avatar
Not true, they recommended I switch my 918's after 10k on my TR230/224 cam.
Old Jun 26, 2003 | 09:32 PM
Phil99TA's Avatar
I've actually been running 941 springs for 18k miles without any problems with my TR 224 cam
Old Jul 1, 2003 | 01:56 AM
JimMueller's Avatar
I've got 19K miles in the past 12 months. I don't drag race and am rarely at redline, but I do auto-x. I have the non-blue stripe version installed, but have a new set waiting. The longer I wait the more paranoid I am. I broke Rev 1115's the last two summers, at between 17K & 22K miles.
Old Jul 1, 2003 | 06:53 AM
RPM WS6's Avatar
How old are your non-blue stripes? If they are from the "bad batch" era in the spring of '02 then you might have cause to be concerned, but if they are older (like winter '01/'02 or before) I would not worry.
If you had a spring from that bad batch I'd think it would have broken long before now.
I would not sweat 19K unless you've got a real aggresive cam and/or big heavy valves.
Old Jul 1, 2003 | 11:20 AM
robertbartsch's Avatar
...i was scared on the 918s since they sent the bad batch out and did not recall it or cover swap expenses and warranty work on the defective product, etc... ...so I bought REVs...
Old Jul 1, 2003 | 05:41 PM
JimMueller's Avatar
I purchased the non-blue stripes around June 24th, 2002. I think I have Rev valves, 2.02/1.57, and the cam is a 218/226 527/535.
Old Jul 1, 2003 | 07:48 PM
RPM WS6's Avatar
I would not worry
But obviously, it's your car and your call. Personally, I have a 221/221//.558/.558 cam with stock valves and 772 ti retainers, and I rev to 6400rpm max. Car does not see redline very often, and I don't intend to replace them any sooner than 30-40K. I bought mine in november/december of '01.
