Best cam with stock headers and Magnaflow
Want to have my engine look stock and get an E.T in the mid-high 11s (with good air).
Have a 2001 formula hardtop/cloth A4 with Vig. 3,600 and 3.73s with good susp stuff and tires, ie 1.58 60' and 12.0s @112 E.T. with a 2,000 rpm launch.
Thanks
Thanks
If you're already at 12.0s I'd bet the Thunder Racing CheatR cam will get you to your goal of mid 11s. Here's what Thunder says about the cam...
"CheaTR" - 214/230 .601/.575 117 LSA. Off Idle-6800 RPM Power Band. Broad power range. Works well with stock exhaust manifolds and catalytic converters. Stock like idle. Minor tuning required on automatic transmission cars. Responds very well to nitrous. Due to the fast ramp rate of this camshaft, the use of 1.8 rockers is not recommended. Double valve springs and titanium retainers required for this cam.
Looks like it'll fit your needs perfectly. Or if you're not to keen on that cam you could always have a similar cam custom ground for you exactly how you want it.
