Flycutting Tools
Old Feb 5, 2010 | 04:46 PM
  #81
frito1's Avatar
I am in the process on putting together a LS2 for my 69 camaro. I tightened up the LSA some and had 4 derees of advance ground in compared to my last LS motor I built. So now the intake valve is opening sooner and I have .018" intake p/v clearance
So I need an intake cutter. I didn't know if anybody had a 2.020" cutter they would rent out for 8 cuts. Or do you know anybody that might have one? PM me with info
Old Feb 5, 2010 | 05:31 PM
  #82
chrs1313's Avatar
i have a 2.04 cutter i could rent out...comes with a brass bushing so you dont have to remove the seals...let me know
Old Feb 5, 2010 | 08:40 PM
  #83
RRhodes1's Avatar
Originally Posted by Boodyrider
Now, now, how many guys here actually have a multi axis CAD/CAM?
Hardly needed. you can see the endmill tooling marks on the cutter head
turn a 8mm stem on a lathe, singlepoint, or use a die to get the threads you want on one end.
as for the cutting head, turn a piece of tool steel to the diameter you want. take it to the mill, find the end mill you want, stick it in a rotary table and make your cutting teeth, run over them with either a beveling tool, or kick the mill head sideways to get the chip clearance angle you want. take the bar back to the lathe, cut the top profile of the cutting head, part it off. drill and tap a hole for the 8mm rod to thread into. call it a day. (heat treat if you want)
not saying it wouldnt be a pain in the *** to make one, just you hardly need a CAD/CAM multi axis CNC to make one. a regular 3 axis manual mill , and a standard lathe with even a 3 jaw with varying soft jaws, is all it takes.
Old Feb 5, 2010 | 09:39 PM
  #84
hcb1700's Avatar
How many times can you use these?
Old Feb 5, 2010 | 11:03 PM
  #85
chrs1313's Avatar
tool steel on aluminum pistons I bet a ton...
Old Feb 14, 2010 | 07:02 PM
  #86
oh5gto's Avatar
Does anybody have a 2.08 cutter I could rent?
Old Apr 13, 2010 | 04:05 AM
  #87
hotrodscrap's Avatar
Subscribing to keep this thread handy, great info, thanks!
-SS
Old Jun 11, 2010 | 01:59 AM
  #88
LilJayV10's Avatar
Bringing this back since I am going to have to do this.
Old Jun 12, 2010 | 12:58 AM
  #89
LilJayV10's Avatar
Originally Posted by 405HP_Z06
They look great, John. The wavy looking chatter marks look much worse in the picture than they really are.
You are correct about indexing a flute on the piston top because, as you state, it can sit between flutes. I did the same and put a mark on the top of the cutter stem to mark flute direction. Thanks for mentioning this.
TTT for those looking at flycutting tools.
Could you explain some more about what you are talking about marking the flute. I am not following.
Thanks.
Old Sep 30, 2010 | 12:34 PM
  #90
on2's Avatar
on2
Anyone have tools I can rent to do 2.02" intake valves?
Old Sep 30, 2010 | 06:42 PM
  #91
Irocss85's Avatar
I'll rent out my whole setup. but you gotta put a safety deposit up. LOTS of reference's if you need. pm me.
Old Sep 30, 2010 | 06:58 PM
  #92
Engine_HP's Avatar
nice helpfull thread, ill come back when i need it.
Old Nov 13, 2010 | 11:52 AM
  #93
samdogmx's Avatar
I need a 1.6 exhaust tool asap. who rents them out these days?
Old Nov 13, 2010 | 12:11 PM
  #94
Intercooler2's Avatar
I just did mine today. I have a 1.57 tool will rent or can buy the setup.
Old Nov 14, 2010 | 04:53 PM
  #95
chrs1313's Avatar
I would just buy one if you only need one...would come out around $100 shipped...
Old Feb 24, 2011 | 04:23 AM
  #96
Raven02TA's Avatar
may need to rent flycutters for 2.02/1.575 valves (or recommended) if anyone has it let me know (for tsp 5.3 stage 2.5 heads)
Old May 3, 2011 | 10:01 PM
  #97
RGSS's Avatar
Keeping the thread alive
Just bought a set for 2.02 & 1.6 valves.
Old Jun 21, 2011 | 04:28 AM
  #98
VYSHSV8's Avatar
yep great advice I will be ordering a set shortly for my new baby cam
251/259 624/624 112 in an Ls1 for some fun
Old Nov 24, 2011 | 05:28 PM
  #99
BBC632Camaro's Avatar
Just wondering if anybody has a set of these flycutting tools for ls3 heads they'd be willing to sell? I believe the valve sizes are 2.165 Intake and 1.59 exhaust. I need a set asap...
Old Nov 24, 2011 | 07:26 PM
  #100
tex1978's Avatar
If you buy a set I would rent them from you to help you out on cost. I dont need them right away but will need them in a few weeks. I just need the intake valve one. Just a thought.
