flow bench results inside!! Ported LS1 vs Ported 5.3 vs Ported LS6
Old 02-04-2008, 08:14 PM
  #41
quiet_storm98's Avatar
Originally Posted by Marc 85Z28
Correction - their advertised numbers are better
exactly
Old 02-04-2008, 08:16 PM
  #42
Originally Posted by AINT SKEERED
nice mid lift numbers to match the peak
i agree..i was really impressed with the mid lift numbers of these heads and to think they cost about the same as the other heads i flowed
Old 02-04-2008, 09:06 PM
  #43
oange ss's Avatar
tried to compile the data for better comparo...the TEA heads are a used set that I recently purchased and supposedly were "hand worked"...the stock LS1 numbers I got from data files that have floatin around the 'net for a number of years
Old 02-04-2008, 09:42 PM
  #44
geovett's Avatar
Unhappy
OK so now we all this data,...my Question is what the h#ll does it equate to??
my quick mods
soon to intall:
5.7 head ported 2.02/1.57
Ms3 cam
tci3600
4.10's
ls6 intake
ls7 lifters
36#injectors
lt headers................now what does it mean in miles perhour..vs ls6 heads
this would help us newbies... HELP HELP HELP!!!CHINE IN !!!!!!!!!!
Old 02-04-2008, 09:46 PM
  #45
nice chart..are you comparing your heads to the ones i have in this thread?
Old 02-04-2008, 09:48 PM
  #46
oange ss's Avatar
not really...was just throwin your data in to an easy to read/compare format and happened to have flow numbers available for mine and threw them in....not tryin to step on anyones toes...just tryin to help...
Old 02-05-2008, 03:13 AM
  #47
DaddySS's Avatar
Good reference, and thanks for taking the time. Much appreciated by the "community"
Old 02-05-2008, 08:43 AM
  #48
Redlinez's Avatar
Kind of shows me you have to weigh out if it's worth it to you to pay for the LS6 heads when you can get 5.3's brand new for $1200. I've been eyeing the PRC's. They have great low/mid lift numbers, and have consistently layed down good numbers from what I've seen.
Old 02-05-2008, 01:46 PM
  #49
Matt87GTA's Avatar
Patriot's ported LS6 heads are $1295....
Old 02-05-2008, 09:25 PM
  #50
oh i know you aren't trying to step on anyones toes..i actually like the fact that you made a graph. It really shows how the heads flow compared to each other
Old 02-05-2008, 09:55 PM
  #51
oange ss's Avatar
Old 05-18-2008, 07:49 PM
  #52
Default added some afr flow numbers to compare to stock ported castings
well i changed my combo up and ended up picking up some slightly used afr 205's and had them flowed..mind you they have a 205cc runner while all the other heads i flowed had runners close to 225cc's
afr 205's milled to 62cc's
.......intake....exhaust
.100 68 ....... 58
.200 140 ..... 119
.300 202 ..... 172
.400 245 ..... 203
.500 277 ..... 219
.600 297 ..... 227
.700 295 ..... 231
as you can see the numbers weren't quite as high as the ported ls6 heads on the intake side but the numbers on the exhaust side were better then any of the other heads plus the small runner should easily make up for the slightly lower flow numbers. Another thing that surprised me is that they actually held their flow up all the way to .700 inches of lift while the stock ported heads all fell off right after .600 inches of lift. Overall they flowed just as good as the ported stockers but they only have a 205cc runner so i should be happy once i put these on
Quick Reply: flow bench results inside!! Ported LS1 vs Ported 5.3 vs Ported LS6
