Need Help!!!!
Old Dec 18, 2007 | 10:11 PM
M. Red WS6's Avatar
Default Need Help!!!!
What kind on damage can you cause to your engine if you disconnect the harness to the ignition coil pack to one side of the engine and you turn on the car???
Old Dec 18, 2007 | 10:19 PM
blkbird's Avatar
What did you do or want to do? If you didnt run it long, i dont think you would have harmed anything.
Old Dec 18, 2007 | 10:26 PM
M. Red WS6's Avatar
I cut it on for less than 3 minutes and reved the engine to 3K without knowing that the right side ignition coils were not connected after installing a set of headers. After I reconnected the ignition coil pack and started the car again I notice smoke coming from the left side which had the ignition coils connected to the wiring harness, like that of burned oil.
Old Dec 18, 2007 | 10:33 PM
blkbird's Avatar
Ive had a couple of wires off the car that i missed and started it up for a couple of minutes as well, didnt do anything to the car. The smoke is probably all of the unburnt fuel.
Old Dec 18, 2007 | 10:36 PM
M. Red WS6's Avatar
I really hope that it is just that!!!
I will try to started up again tomorrow and see what I get, thanks for the input BLKBIRD.
Old Dec 19, 2007 | 05:51 AM
g-ryde1's Avatar
whenever ive installed headers there was always smoke coming from the engine bay so would say your good
Old Dec 19, 2007 | 08:17 AM
radkon's Avatar
The side that was disconnected got a lot of fuel during that time. Possible long term effects are ring issues (from the gas thinning the oil) and CAT damage but I think you'll be fine. I would change your oil right away.
Old Dec 20, 2007 | 09:36 PM
M. Red WS6's Avatar
Thanks for all your help guys (RadKon, g-ryde1, blkbird)
I got the car started and after running for a couple of minutes the the smoke finally subsided. The sound from the headers is awesome
Old Dec 21, 2007 | 06:42 AM
blkbird's Avatar
Good to hear that everythings ok!!
Old Dec 21, 2007 | 07:31 AM
crainholio's Avatar
Recommend you change your oil soon, all that unburned fuel isn't doing it any favors.
Old Dec 21, 2007 | 07:49 PM
M. Red WS6's Avatar
Oil has been changed, thanks again for all your input guys!
