LS1 to LS2 timing chain-doesn't it need to be lubed?
Old Dec 26, 2007 | 06:10 PM
Weezzer's Avatar
Default LS1 to LS2 timing chain-doesn't it need to be lubed?
Doesn't the timing chain need to be lightly lubed with a good spray lubricant upon installation?
Old Dec 26, 2007 | 06:11 PM
blkbird's Avatar
Just dip it in some oil before you put it on and you should be ok.
Old Dec 26, 2007 | 07:24 PM
3.4camaro's Avatar
It'll be good and covered in oil within 10 seconds of initial startup.
Old Dec 26, 2007 | 07:47 PM
Ryan02SS's Avatar
You always want to lube a new TC with oil before break in. Never just throw it on and go. I always lube them with an oil can squirter and turn the engine over a few times with the plugs out to further lubricate the chain.
Old Dec 26, 2007 | 11:11 PM
rocksws6's Avatar
No lube on mine and its just fine, but it definatley won't hurt anything to lube it up a little. I hear KY jelly works real good.
Old Dec 27, 2007 | 12:01 AM
Boosted 99 TA's Avatar
i never lubed mine when did my cam swap, ive drove about 6k since then but you might as well.
Old Dec 27, 2007 | 01:06 PM
vettenuts's Avatar
Lube it up good. I actually used some Redline Assembly Lube on mine. This is splash fed so it will take some time to be properly lubricated, I wouldn't put it on dry. Hit it with an oil can just before installing the timing cover.
Old Dec 27, 2007 | 03:12 PM
1badA3Z's Avatar
No oil ever on mine,havent had any issues with it yet,but guess its whatever u feel better with doing,hope this helps!
Old Dec 27, 2007 | 03:22 PM
1Bad00SS's Avatar
I just rubbed a little assembly lube on the inside of the chain and let her rip.
Old Dec 27, 2007 | 07:27 PM
Weezzer's Avatar
Common sense was gnawing at me to lube it since I opened the package it came in.
I bought the red line assy lube for my cam change, perhaps I'll throw a little of that on there.
Appreciate the thoughts...
BTW- that crank bolt was hell to break free...
Old Dec 27, 2007 | 09:12 PM
vettenuts's Avatar
Redline is great stuff. I used it on the lobes and bearings on the last cam change. It dissolves instantly as soon as oil hits it. I also used it on the pushrods, rockers and top of the valve stems after soaking the pushrods in oil to pre-fill them.
Old Dec 28, 2007 | 12:35 AM
Damian's Avatar
LSX Mechanic
A little mystery lubricating oil works fine. Thats what I use. It soaks onto the chain and doesn't drip.
