Does anyone have a cam retainer plate handy?
Old 02-13-2009, 06:37 PM
vettenuts's Avatar
Originally Posted by deejaydaze
Thanks for the help. It would be nice if the website had the same result during the lookup of 12589016
Anyone know what the ARP bolts in the kit look like???
(part #134-1002) I'm thinking it's not counter-sunk style.
No they are not so if you have the new plate you cannot use them.
Old 02-13-2009, 06:42 PM
deejaydaze's Avatar
ARP bolts for sale then!!!
Old 02-14-2009, 12:43 AM
HavATampa's Avatar
So p/n 12589016 is the new plate with countersunk holes and p/n 11561455 is the correct bolt for the plate. I'm assuming that bolt part number is for just one bolt and not the 4 needed for the plate?
Old 02-14-2009, 03:01 AM
WhiteRhino's Avatar
Correct. That is for one bolt. So x4 when ordering that part number.
Old 02-14-2009, 06:51 AM
vettenuts's Avatar
Installation torque is different as well, if you use 18 lb-ft the plate will split. According to my notes it is 11 lb-ft.
Old 02-14-2009, 06:58 AM
HavATampa's Avatar
The 4 bolts cost almost as much as the plate.
Thanks for the torque tip!
Old 02-15-2009, 12:58 AM
WhiteRhino's Avatar
I went 18 ftlbs. Didn't know there was a lower toqrue setting. My plate didn't crack or split. I tightened them in small hand turns, before bumping up to 18 ftlb. Will this cause issues in the long term? Or should it be ok? I really don't want to tear down the front of the motor since I finally got it back into the car...
Old 02-15-2009, 07:34 AM
vettenuts's Avatar
I don't know. A few guys had them split, I have even heard of a few cases where the factory installed plate was split. I wouldn't think it would be an issue, however the plate is the block off for the oil gallery so if you see your oil pressure heading south at some point in the future you may want to check this plate.
Old 05-23-2011, 11:21 AM
TehGODofGreen's Avatar
Default digging up for comfimation
Is the gasket the same? Doing a build I already have the original flat style plate and arp bolts I just need the gasket.
Old 05-23-2011, 12:45 PM
LS 63 Nova's Avatar
From what I have seen the gasket is not available seperately. You must buy the plate to get the gasket. Someone posted they got a Victor brand plate from Car Quest and it was the old style, I'll be checking that out soon.
Old 05-23-2011, 02:04 PM
No I was asking if I buy a new plate are the gaskets the same? I want to use the flat plate because I already have arp bolts for it. If the gasket is different then ill just buy the new style bolts I'm just trying to save 12$ that could be spent elsewhere.
Old 05-23-2011, 06:19 PM
  #32
Steve01SS's Avatar
I don't think you can remove the seal/gasket from the plate. It seems bonded. I wouldn't try and screw with it. If that gasket/seal is even nicked, then you can lose oil pressure.
I have the ARP bolts and they are for the older flat plate. I had bought a new plate from Katech awhile back and it's the older type. Worse comes to worse, sell the bolts and buy the new type.
Old 05-23-2011, 10:47 PM
  #33
theevette's Avatar
Carquest has the oe Plates made
By victor reinz. I just got mine last week
For 18 bucks I was able to use stock bolts
Old 05-24-2011, 04:36 AM
  #34
vettenuts's Avatar
Not sure if you still have it out of the car, if so can you post a photo?
Old 05-24-2011, 10:00 AM
  #35
LS 63 Nova's Avatar
Both style plates use the same seal you just have to match the correct bolts and torque to the style of plate you are using.
Flat plate at bolt holes: hex head bolts - 18 ft. lbs.
Counter sunk holes: torx drive, flat head bolts - 11 ft. lbs.
Old 05-24-2011, 10:02 AM
  #36
I know where 2 Carquest are i will look into it this week or the next.
Old 05-26-2011, 11:04 PM
  #37
theevette's Avatar
It's a fact fired mine up yesterday and everything worked out perfect I will post a pic if someone will tell me how from a IPhone
Old 05-27-2011, 03:56 AM
  #38
vettenuts's Avatar
You need to upload the pic to photobucket or other host. Then you can link it in with the yellow picture icon when doing a reply.
Old 05-27-2011, 12:40 PM
  #39
CodyBoy's Avatar
Are the plates in ya'lls cars the same as my truck?
The only seal mine had was orange RTV in the groove cut in the back of it.
You could tell it wasn't a seal/gasket, as you could see the excess where it oozed out.
Just curious.
Thanks
Old 05-27-2011, 02:11 PM
  #40
joecar's Avatar
Are you saying they have the non-countersunk bolt holes...?
Quick Reply: Does anyone have a cam retainer plate handy?
