Cam Questions.
You could do two things:
1- Mill the heads .018 (3.5cc) for a final 61.5cc chamber and a ~11:1 SCR with stock gasket.
Or
2-you can run a .040 Cometic gasket (or equivalent) and therefore increase SCR that way while improving quench as well. .040 gasket will reduce SCR by ~ 2.5cc
(That is with the Patriot cam)
Or
Well the heads are new. So I would prefer to run the cometic gaskets then I guess. do you know of a good place to buy them? I was just going to use one of the gm head and cam swap kits.
