Out the bottom with no lift?
What all do you unbolt to lift the car? Where do you stick the hooks?
Do you just chalk the tires and leave them on the ground?
Thanks, guys. If anyone knows where those pics are, I'd like to see them.
https://ls1tech.com/forums/generation-iii-internal-engine/354351-how-remove-engine-bottom.html
https://ls1tech.com/forums/generation-iv-internal-engine/433240-started-install-my-ls2-402-slp-w-pics.html
1) Here's how I set up the hoist. There's no need for hooks, just a good pair of chains and Grade-8 bolts with washers. Wrap the crossbrace with cardboard or something to keep the chains from damaging the paint.
2) Disconnect:
- Drain motor oil, tranny fluid and radiator.
- 2 front Brake lines from ABS block, get the lines off the retainer on the driver side and zip-tie them away from anything they might tangle with.
- Remove radiator and fans assembly.
- Exhaust from headers at collectors.
- Fuel lines.
- Steering knuckle.
- Shifter boot and ****. (you can leave the shifter in place).
- All top-end sensors (MAF, IAC, Injector harness, MAP, Vaccum lines in back of manifold, Throttle cable, etc).
- Wires going to ground bolts on each side of engine block, Starter wires, Crank Pos sensor behind starter
- Disconnect all wires going to both sides of tranny (T-56)
- Take off driveshaft.
- One connector on each side going to brakes.
- All tranny connectors
- Support tranny and remove Tranny Support Bracket.
- Support motor from under K-member and take out 6 bolts (3 on each side) that hold K-Member to the body of the car (they are right next to the lower control arms).
I might have missed something but you get the idea.
IMPORTANT:
You do NOT have to disconnect the A/C lines (see picture below). Just lower the k-member a bit and then unbolt the A/C compressor and rotate it out of the way. I zip-tied mine to the lower radiator support bracket.
And you are done:
Guys, just be carefull lifting the cars with the hoist. I saw a mark 8 done that way one time and the lift was placed infront of the car. The car tipped over as they were trying to pull the motor from underneath, someone neglected to notice he was pulling himself against the car and the engine hoist started to tip and never stopped. Good thing the car was a junker and it was a motor salvage! Just becareful, thats still a lot of weight up in the air even without the motor and tranny.
Not to mention the sh*tload of extra wrenching you have to do.
It's all in personal preference. Without a lift, I do everything from under the hood. With a lift, it's a given to do it from underneath.
