Cam setup help please
Pacesetter Longtube headers
Pacesetter off-road connection pipes
HPE Cam of your choice (listed below)
Comp Cams *NEW* .650 lift 918 valve springs
Comp Cam 7.400 pushrods
NGK TR6 Spark Plugs
160* thermostat
Mobil 1 oil change
Price: 2076.12
1 day turn around time, installation and tuning included.
Call or email me to set up an appointment.
281-477-3100 or chuck@horsepowerengineering.com
Here's the cam list to choose from.
Comp Cam- 224/230 on a 112 LSA 581/592 lift
C cam- 232/234 on a 112 LSA 595/598 lift
Blower grind- 235/242 on a 115 LSA 648/610 lift
C+ cam- 236/238 on a 112 LSA 602/605 lift
S cam- 238/240 on a 112 LSA 605/609 lift
S+ cam- 238/242 on a 113 LSA 605/610 lift
S2 cam- 239/242 on a 112 LSA 651/610 lift
Mega Death cam- 244/242 on a 112 LSA 612/610 lift
My questions are:
1. Is $2100.00 a good price for this setup?
2. I would be going with an S cam. I really don't want to have daily driveability problems or any serious mechanical problems because of maybe lcaking other things in the setup.
3. I was told a better set of rockers, lifters, and a double roller timing chain were not necessary and that generally these can withstand a cam and some abuse. Also, I know without an ls6 or fast intake I won't be getting all the power I should, but I just really love the sound of a cam and am waiting for my buddy to sell me his fast 90 and throttle body this summer.
I read the "cam guide" and know that valve springs and pushrods are a must have. Just curious as to know if lifters rockers, and timing chain were necessary...meaning that without them the car won't be a time bomb.
Thanks for all your help,
Brian
O and the car is sitting at about 64K miles right now.
As for the cam, if you're looking more for sound (rather than all out performance) and your car is a daily driver, you might want to go with the C cam. It should give you a pretty good choppy sound, however can still be easily tuned to run smoothly (not to mention it will probably help you out a bit down low and mid-range).
