what push rods do i need?
Old 01-04-2008, 11:23 PM
Disturbed Bird's Avatar
Default what push rods do i need?
i know i need a hardened push rod but what length?
i bought patriot performance stage 2 with 59cc
Old 01-04-2008, 11:28 PM
spookyz28's Avatar
What year is the car, what kind of head are you running, are the head's milled at all. If stock go with cromoly comp cams 7.400
Old 01-04-2008, 11:29 PM
spookyz28's Avatar
my bad with your head's the 7.400 should be fine.
Old 01-04-2008, 11:35 PM
ya i dont know if they are milled or not.
Old 01-05-2008, 08:32 AM
vettenuts's Avatar
Spend $20, buy an adjustable pushrod and measure. That way you know for sure.
Old 01-05-2008, 08:47 AM
bjamick's Avatar
Im sure you will be just fine with a 7.4 hardened. If you just want to know then measure but most of the time a 7.4 will work just fine.
Old 01-05-2008, 10:33 AM
allthrotle's Avatar
Im running 7.4's with the same heads. the Patriot heads have not been milled. You can run the stock pushrod length. If your looking for a good set of pushrods on a budget then get the trick flow's. Theyre 5/16 chromemoly with a .080 wall. You can pick them up for like 87 dollars plus shipping.
Old 01-05-2008, 01:42 PM
cool thanks
Old 01-05-2008, 02:07 PM
JPH
JPH's Avatar
yeah, I agree with everyone else and you should be okay with 7.400. Doesn't hurt to verify though.
