NHF, 10mm tap 2.0 pitch ?????
need help fast, do they make a 10mm tap with a 2.0 pitch, if s o where, i dont care on cost, i just need it asap. we are trying to clean the treads on the block for the main studs.
thanks for any help, if you could just p.m. me, thanks
Your correct on the size and thread pitch, M10 x 2.0.
As far as the 'tap' that comes with the Kent Moore/SPX thread repair kit. GM specifically states that these tools CAN be used to clean the threads for main and head bolt holes. From the GM service manual under cylinder head replacement, "Clean the engine block cylinder head bolt holes, if required. Thread repair tool J 42385-107 may be used to clean the threads of old threadlocking material."
If you can find a metal cutting 'tap' in M11 x 2.0 or M10 x 2.0 in the bottoming or taper variety please let me know.
Do you still have the complete Kent Moore/SPX Timesert GM Gen III thread repair kit? If so please contact me at 346-571-5926, i'd like to buy it. Thank you.
After ELEVEN years? Ya think you'll get an answer?
WHOA. Will wonders never cease...
