Introducing K1 Technologies/Wiseco Rotating Assemblies! WRE 40th Anniversary Specials
The standard K394F05 and the standard ring pack would be more than adequate for the amount of nitrous you have planned to use.
The price for the 403 or the 408 Iron block would be the same. If you are using alot of nitrous I would recommend the stage 2 408/3. This a full CNC blueprinted block. I would also do the ARP main studs. The total on that would be $4250. That is also giving you $14 off the main stud upgrade.
OWN3D BY MY PROF!
If I had the money for a nice assembly I'd be all over this, but
I don't. I know this is kind of random, but does this sale extend to these products individually? I already have some pistons and will be using the stock crank, but need rods. Does K1 make a 6.098 rod with a .945 pin? I checked your site and only saw the .927. Thanks and good luck with the sale.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Thanks,
Leo
