Head Flow numbers Tell me what you think?
Old 07-08-2003, 11:13 AM
Zatlanta's Avatar
Default Re: Head Flow numbers Tell me what you think?
You ask a good question about the exhaust flow vs intake.. I'm working with a porter who reccommends closer to a 70% I/E ratio, like what you are looking at. I'm going with it, and I'd like to hear what others have to say on the issue..
Old 07-08-2003, 11:31 PM
99 Black Bird T/A's Avatar
Received 1,443 Likes on 1,001 Posts
TEA stage 1.5 and 2.0 heads flow 220-224 exhaust max without a pipe. They flow 296 intake max. I was talking to the guys at Texas Speed and LS1 Speeed. Both flow tested the heads on there own.
That's interesting, my heads would only flow 200 w/o pipe. Not a gripe just stating the results from when my heads were flowed. Intake was 292-296 when my heads were flowed very close to the numbers TEA gave me.
Old 07-09-2003, 09:36 AM
6600 rpm clutch dump of death Administrator
J-Rod's Avatar
The reason those heads flow like they do, is that the SCCA and GM want a certain number, at a certain lift, etc... I have flow numbers for those heads @ MTI. I posted a thread on this a long time ago, its proably in the archives if you are interested.
Old 07-09-2003, 06:33 PM
J-Rod's Avatar
Here is the link to my webspace with all the flowsheets. I have the SDPC numbers and the ones from MTI. My msg covered what MTI said about the heads. I will try to dig it up and post it.
Anyhow, here is the LS6 flow numbers.
Also, I have a spreadsheet
http://users3.ev1.net/~black_ops/hea...s-01-03-03.htm
With all the flow numbers, ls1 and ls6
Old 07-09-2003, 09:04 PM
Bowtieman4life's Avatar
Call a shop that sells all four and ask there opinion.
Old 07-10-2003, 12:59 AM
Carbon's Avatar
good choice Jeff!!!!
Old 07-11-2003, 04:41 PM
TT-TECH Veteran
Inspector12's Avatar
Thanks J-Rod that is very good information for the Idiots such as myself about Head flow numbers. A lot of people should look at this. Althought flow is justone aspect of a good running car it is a good place to start!
