Cam For A 402?
Old 01-15-2008, 07:14 PM
Restricted User
SSkid99's Avatar
Default Cam For A 402?
Hey i built a low compression 402 and i need help with what cam to go with i dont know which one to do cause i have never done a low compression motor ill also be spraying to so i dont know if i should go with a low and mid range cam or mid and high range cam need help everyone thanks
Old 01-15-2008, 08:08 PM
therealthatguy's Avatar
i would say low to mid 230's.....
Old 01-15-2008, 08:28 PM
HEMIETR's Avatar
Why low compression? Do you have plans on going FI?
Old 01-15-2008, 08:51 PM
Shawn @ VA Speed's Avatar
how about some specs-compression,heads,intake,headers,weight of car,m6-a4,rear gear?
Old 01-15-2008, 10:33 PM
Restricted User
SSkid99's Avatar
yea im goin to either procharge it or spray alot so i was looking for a good cam to make power with
Old 01-16-2008, 07:15 AM
slow trap's Avatar
nitrous loves compression you will just be leaving hp on the table if you wind up just spraying it but as in low do you mean like 9:5 or so ?
