Wrench in oil pan...
While taking off the oil pick up tube to fix an obviously defective o ring, I dropped my 10mm wrench in the oil pan...
I have tried for hours to get the thing out, but it went all the way down to the bottom. Is it alright to leave it there and just bolt everything back up? Or should I pull the motor and get the wrench out.... any other ideas?
TIA,
Joe
Any other ideas? I don't have an engine lift available, but I guess I could go rent one or something. It is starting to look like I am going to have to.
http://www.circuitflex.com/OilPan1.jpg
http://www.circuitflex.com/OilPan2.jpg
Dale, those pics actually do help out alot, at least now I know where I have to fish around at. Thanks!!!
GoFast, I will dig up an old speaker and try that. I sure hope it works out, this is getting old real fast. I have been doing this all day. Guess I am not taking my car to camaro superfest today :-{
I had no luck digging up an old speaker that is strong enough to move the wrench. When I shake the pan I can hear the wrench in there, but I cannot see it ANYWHERE in there when I look.
What is the easiest way to get to those two motor mount bolts with long tubes in the way??
I must say that I have learned alot from this experience which should have taken maybe 30 minutes from start to finish. So I will share my hard earned knowledge with all my LS1tech helpers out there:
When taking the bolt off of the oil tube pick up, TIE A STRING TO THE 10 MM WRENCH so if you do drop it you just pull it out. Tie the other end to the sway bar or something too. Just my word of advice for everyone....
Joe
When I was doing my oil pump, I dropped the bolt in the pan... thought for sure it was in the deep end... well Big D came by my house and all he had to do was rotate the crank and there the bolt was... it was hiding behind the rod cap.
Worst case, as was mentioned above, take off the accessories (condensor and alternator), disconnect the bolts that hold the motor to the motor mounts, push up on the motor w/a jack and lower the pan enough to stick your hand in....
...they took the pan off!
Suggestion: search here for the posts about changing rod bolts while the motor is in the car....they will tell you how to remove the pan...
