Big cam for stock cubes????
Old Jul 5, 2003 | 07:06 PM
Gold Phoenix's Avatar
Default Big cam for stock cubes????
I looking at MMS stage 3 blower cam for my stock displacement forged motor with heads, but with nitrous instead of a blower. The specs are 233/244 115LDA and .578"/.602" lift. The motor will have over 11:1 compression. Will this cam be streetable enough for weekend cruise? I am hoping for max power with a hyd cam and stock cubes. I know I have seen a video of Thunder Racing's Reverse Split cam with 230 intake duration but they use a 111LDA which would make to motor idle lopey. Anyone else with similar parts?
Old Jul 5, 2003 | 07:45 PM
VINCE's Avatar
Shorty Director
Default Re: Big cam for stock cubes????
As long as you have valve reliefs and good tuning. I see no problem.. I have a big cam, but not that big on the exhaust side.. I cruise around every weekend and do not have any issues. I have 4.10's and still get 26mpg on the highway..
Old Jul 5, 2003 | 10:25 PM
someday's Avatar
LDA? do u mean LSA?? a cam THAT big on a 115LSA would be good in a 388 motor... it will peak around 7000 in a 346 with heads... wonder how smooth it would be tho??
Old Jul 5, 2003 | 10:56 PM
LDA = Lobe Displacement Angle. Same Difference. That is peak I want. With a big shot of nitrous, the peak will move lower in rpms so I won't have to rev it past 7K.
Old Jul 6, 2003 | 10:24 AM
I looking at MMS stage 3 blower cam for my stock displacement FORGED motor with heads, but with nitrous instead of a blower.
A 112 LDA will make the idle choppy and the split duration isn't wide enough
Old Jul 6, 2003 | 10:25 AM
OK what happened to Ian's post?
Old Jul 6, 2003 | 11:44 PM
Ian's Avatar
Ian
I deleted it. I read your post too fast, and didn't realized you were wanting the cam for a forged internal motor. With that done, it shouldn't be a problem spinning to the 7k mark as long as you're properly set up (fuel/tuning). A 112 LSA cam isn't too harsh running through a full exhaust though. All depends on where in the band you want your power I guess. Best of luck with the combo. Make sure to keep us up to date on how it turns out!
Old Jul 7, 2003 | 06:23 AM
DONAIMIAN's Avatar
Just because its on a 115LSA dosent really mean that it will idle smoother than the TR230. With all that duration, I wouldnt be supprised if it idles just like it.
Old Jul 7, 2003 | 08:23 AM
Well still, I want the wider LSA to keep the unburned nitrous from going out the exhaust. And with wider LSA's, it has shown to smooth out the idle of the same duration. I am not saying it will idle like stock, but it will be alittle better than a 111LSA. I
Old Jul 7, 2003 | 01:54 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I ran a 236/240//111 a few years ago and it loped but idled fine after it was warmed up.
I also ran a 232/232//116 a long time ago and it idled like a B1.
