C5R heads?
Old Jul 6, 2003 | 03:53 AM
mastrdrver's Avatar
Default C5R heads?
Will these heads work on a LS1 block with a LS1/6 intake? Also are they center or perimater bolt valve covers?
Thanks
Jeremy
Old Jul 6, 2003 | 07:01 AM
marco383's Avatar
Default Re: C5R heads?
C5R heads require a custom intake manifold and have very small combustion chambers (39CC if my memory is working this morning). This will result in a race-gas-only C.R. unless custom, dished pistons are used.
Too much hassle for the gain vs. a good set of ported lS6 heads.
Old Jul 6, 2003 | 07:21 AM
v8 ute's Avatar
You wouldn't want to use a set of these on a std bore LS1, they simply wouldnt work.
Old Jul 6, 2003 | 10:48 AM
grb's Avatar
grb
LWA has a set of used ones set up for a solid roller and complete with titanium valves. Pretty much for high RPM use.
Old Jul 6, 2003 | 08:32 PM
Bink's Avatar
How much do they want for the set?TIA.
joel(Bink)_
Old Jul 7, 2003 | 02:27 AM
CAMN HAWK's Avatar
FASTEST ALL MOTOR LS1 IN THE COUNTRY
GRB.....
WHAT DO THEY WANT FOR THE C5R HEADS?? AND ARE THEY FULLY PORTED??
Old Jul 7, 2003 | 08:05 AM
ls1290's Avatar
Dumb Ass Vette Moderator
A single bare head goes for about $1200. There are not many shops that port these heads and the ones that do like Kaltech, they are about $5K not including the heads.
Old Jul 7, 2003 | 11:19 AM
grb's Avatar
grb
I think $3k. LWA phone # 1-770-449-0315. These heads were bought from Katech after some use. I don't know how much.
