Comp 987 springs....
Old 07-06-2003, 02:04 PM
7 Second Club
Phil99vette's Avatar
Default Comp 987 springs....
I called one of the leading LS1 cylinder head vendors last week and was told that the Comp 987s are not a very good spring. After looking on the Comp web site their catalog said that the 987s were only recommended to a .500" lift cam. Any input?
Phillip
Old 07-06-2003, 02:35 PM
Larry's Avatar
Default Re: Comp 987 springs....
121# @ 1.800
388# @ 1.200
Should be good to .600 lift. Coil bind is 1.150.
Old 07-06-2003, 04:49 PM
needmoremoney's Avatar
wait a minute! My SII heads came with 987's double valve springs. I was told that there good up to .630 lift. As they better, becuase my cam is 228/236 .571 .602 111LSA
Old 07-06-2003, 09:32 PM
Larry's Avatar
I don't think that .002 thousandths is going to be a problem. I do think .630 would be as you would be within .020 of coil bind. Who ever told you .630 was wrong unless they were set up at a higher installed height than 1.800. Of course then you lose load.
Old 07-06-2003, 09:42 PM
Wait, I don't understand what your telling me?
