Best Street/Strip Cam
Old Jan 20, 2008 | 02:20 AM
VaderZ's Avatar
Default Best Street/Strip Cam
What cam would you all recommend for a 2002 Z28 ls1 346 with the following mods already in it; LT w/Y, svo 30lbs injectors, 3600 vig. stall, electric cut out and 3.42 gears...The car a true daily driver and see the track occasionally on the weekends...I want a all motor cam only, don't plan on shooting nitrous...Thanks for your help...
Old Jan 20, 2008 | 02:31 AM
tatasta's Avatar
TR224 on 112, good street manners, enough lope to hear it and great power under the curve and easy to tune. Will work well w/ your stall.
Old Jan 20, 2008 | 03:06 AM
mohammed_k81's Avatar
This is a bad *** Cam G5X3 '112' Lobe
Its has a really good idel
Old Jan 20, 2008 | 09:11 AM
John02Hawk's Avatar
If you want to get the "best cam" for your mods and driving habits, your best bet is to get one custom spec'd for you. Patrick G here on the board did that for me..
Old Jan 20, 2008 | 09:23 AM
Shawn @ VA Speed's Avatar
pm sent
Old Jan 20, 2008 | 09:46 AM
TA1364's Avatar
^^ Whats the cam specs? Ive seen u bring it up before in other posts
Old Jan 20, 2008 | 11:03 AM
bad6as's Avatar
a cam in the low 230's durration should do great
Old Jan 20, 2008 | 11:58 AM
JPH's Avatar
JPH
good answer man. I was thinking 232/236 .600/.600 112+4
Old Jan 20, 2008 | 12:00 PM
bad6as's Avatar
i would go bigger for my self but im sticking to 6500 shifts im going a 232/234 110+2
Old Jan 20, 2008 | 12:39 PM
rel3rd's Avatar
With pretty much the same mods as you have, I went 11.67@115 on drag radials with a "baby" 226 cam. Mine's an older "custom" Comp grind, but it's VERY similar to the one Patriot offers, just has slightly more lift. Idle is definitely noticeable, without being obnoxious or temperamental.
Here's two quick vids of how it sounds...
w/stock catback:
http://www.fquick.com/videos/stock_c...Camaro_SS/3815
with 3" single in/out catback:
http://www.fquick.com/videos/New_3_q...t_catback/4021
Old Jan 20, 2008 | 11:28 PM
VaderZ's Avatar
Old Jan 20, 2008 | 11:37 PM
socal's Avatar
TSP 233/239 lsa 114 is what i'm going to run w the same set up + 150 shot
Old Jan 20, 2008 | 11:44 PM
VaderZ's Avatar
let me know your times...
Old Jan 21, 2008 | 10:50 AM
slimcracka's Avatar
228r imo
or break the mold and go different
https://ls1tech.com/forums/generation-iii-internal-engine/652563-reverse-torquer-cam-other-side-coin.html
Old Jan 21, 2008 | 10:55 AM
99Hawk262's Avatar
I have a TR230/224 and love it. I'm 95% street but it has good manners and makes great power.
Old Jan 21, 2008 | 11:27 AM
bad2000z's Avatar
X1 on a 112lsa.
Old Jan 21, 2008 | 11:31 AM
socal's Avatar
it will be a little while before i get the car on the road (time) but we do have the cam in an ls2 w l92 heads it made 423 rwhp and ran slower et's since the clutch wouldn't hold it but its a great dd in that car
Old Jan 21, 2008 | 11:37 AM
Tuner@Straightline's Avatar
We've been using this cam for a few years now with great success. I had it in my car for over a year as a dailey driver. I'd recommend it to anybody that doesn't mind a little shake at idle.
