Blower Cam Question
Old Jan 21, 2008 | 06:42 AM
01LS1Trooper's Avatar
Default Blower Cam Question
I'm looking at a cam to pair up with the Eaton 112 I'm gonna pick up from LMSpeed, and I was wondering if anyone could give me some advice. I want something with some lope to it, and I'm not too concerned on low end power / torque as the Maggie will take care of that. This will be run with LTs and a Spec 3+. I don't want something that will drive like *** on the street as it's where 90% of this cars time will be.
Options:
224/232 .581/.595 114 (114 might bleed off boost?)
or the one I really want from EPP
232/240 .595/.608 115
Now keep in mind this is with STOCK heads. So will PV clearance be a problem with this one? Just for anyone curious here is the EPP Cam.
Old Jan 21, 2008 | 07:09 AM
krobinson123's Avatar
That epp cam is going to be too big of a cam for a stock bottom end and a blower
Old Jan 21, 2008 | 10:44 AM
JPH's Avatar
JPH
use 224/232 cam.
Old Jan 21, 2008 | 01:30 PM
Yes the EPP one is a little extreme. I think the first may suit my needs better. The first cam is a SC2 by Speed Inc, by the way.
Old Jan 22, 2008 | 03:21 AM
yotaman96's Avatar
I'd like to see what #'s the EPP cam makes with the maggie.
Old Jan 22, 2008 | 07:13 AM
What would it take to get that cam to work in my engine?
Old Jan 22, 2008 | 09:45 AM
yotaman96's Avatar
I think it would work. Call or message EPP and let us know what they say.
Old Jan 22, 2008 | 06:38 PM
Tom@SpeedInc's Avatar
Options:
The cam I would recommend is our SC1 222/228 .564/.571 114
"Bleeding off boost" its an assumption, but doesn't actually happen
One of highest dynoing blower car we've had used a 112 LSA cam FWIW
Old Jan 23, 2008 | 11:15 AM
Good to know. Thanks Fraser. So why do people say bleeding off boost does happen?
Old Jan 23, 2008 | 11:44 AM
How something looks on paper and how something performs in the real world can be two entirely different elements.
I would have never guessed a 232/234 .595/.598 112+2 cam would be a well performing blower cam, but it worked. Have to think outside the box I guess?
What i've noticed, overlap works likewise for N/A as it does forced induction.
I would consider the 'bleeding off boost' mentality when the exhaust port had flow similar to the intake port, but from what i've witnessed, the exhaust doesn't flow enough.
