So Lost on picking a cam...I have researched and researched and...
#41
Overlap is the end result of two opposing durations and the distance between them, or the lobe separation angle. Look at the drawing below, representing two single pattern cams (intake and exhaust duration are the same on each cam).
On the first cam, the two lobes are farther apart, on a wide LSA as we would say. Note the area of the overlap triangle from Cam 1 compared to Cam 2. The durations of all four lobes are the same, the only change is to bring them closer together, which increases the amount of overlap.
The +2 and +4 is meant to signify advance not a change in LSA.
#42
I'd go TR224 on 114LSA. Cams with little to no lope rock. Who's gonna pick a race with someone who obviously looks and sounds like they could lay waste you without raising their oil temperature.
Re'
#43
Lets see if I understand, the only way overlap is changed is by changing the LSA. Advancing the cam isnt something ground into the cam. Advancing a cam brings down the peak X amount of rpms. Seem right?
Back to the 228/232, 110 no adavance, +2, or +4? Why not go with 112 to keep overlap down and streetability up?
#44
As for the last question I am not sure on but im sure somebody will know.
#45
LS1 Tech Administrator
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
#47
An engine will want certain valve events. Assuming the save IVO and IVC, widening the LSA will open the exhaust valve earlier. This can bleed off cylinder pressure on the power stroke prematurely, reducing torque. The earlier EVC reduces overlap, which can also reduce power. There's no free lunch. Often, what you gain in street manners, you lose in power under the curve.
For a 228/232 cam what lsa and advance if any, without spinning real high would you suggest then?
#48
Its just best to ask the guys who know like Patrick G.
Thats the one thing i learned from reading all those thread which was to talk to him. Its worth it to have him custom spec a cam for your application for an extra 25 bucks...def worth it to have high average number through the curve.
#52
the OP *MAY* do CNC heads later...
bottom line I would do a custom cam or something a bit bigger (above 235 and above .600 on both sides) than your original thoughts. Point is you don't know how far you want to go with your car in the future, so make the swap worth it. Meaning something that will give you enough power to satisfy, I got help with some specifications on a custom cam. Basically some quick intake lobes, split, with about 4 degrees of advance to get it in the pants (just a street car) anyways my opinion, take your time. Maybe try to find some cars in person that are running these? Just an idea, but I know people with cams aren't always just hanging out in a parking lot.
#53
"Maybe try to find some cars in person that are running these? Just an idea, but I know people with cams aren't always just hanging out in a parking lot."
I wish it was that easy... I cant even find another LS1 within 45 min. of me.
I feel like i really am "The last of the Breed"
In the sticks!!!! lol
#58
Very true. Lots of people over think the cam they pick and under think the tuning. TTP put their Equalizer V3 cam in the car in my sig. I have only put ~ 500 miles on it since I bought it. The clutch is far worse than the motor for DD and it isn't bad at all. TTP did a really great job tuning it. The previous owner gave me the dyno sheets with the car and the torque curve isn't really a curve. It's a straight line more or less. It makes 340+rwtq at 1700RPM. That makes this car really well mannered on the street. The V3 is a pretty big cam too. I don't know the specs on it but it sure sounds good. I'll have to find my camera cable and post up pics of the dyno graph. What a DD is defined as is different for everyone. You seem to have a good idea of what you want. The only other thing I could suggest is taking a ride in some cars with different setups. If your in the GA/SC area I'll give you a ride.
