Lifter choice with F14 highlift
I would go with Morels first or Caddies second. Not sure what the base circle is on that cam since it has higher lift but as the lifter starts sitting lower in the bore it can starve for oil. The Morels are designed to handle the lower position. I believe the Caddy lifters have features to prevent oil starvation as well but am not 100% positive of that.
LS1TECH & Trucks Sponsor
LS7 lifters are good to 7500 rpm, after that the Caddy CTS-V racing lifters are recommended, they have reduced mass internals and are good to 8000.
I keep both in stock and can make any of you a deal you won't beat
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
LS7s will do just about any LSx build you could have in mind, you would only need Caddy lifters if you went over 7500. It's nice to know GM has a quality part that is good to 8,000 if you need one though
__________________
