98 heads with lightened Z06 valves?
I have a set (actually 2 of em) of stock 98 LS1 heads that I plan to have milled .030 to raise the compression. I am also going to be using a 230/224 cam with a maximum lift of .578". This setup will be going into my rx-7 v-8 conversion and I purposely picked a cam that I can get good power on the top end as I am worried about traction on the low end. To get the rpm's up reliably I would like to lighten the valve train as much as possible. My question is, will the Z06 lightened valves work with this setup? I understand they are slightly longer and I'm not sure if they will fit well while maintaining good spring seat pressure AND not hit the piston. Can anyone help?
Thanks,
Chris
Thanks,
Chris
