afr 205 vs tfs 215???
Okay, so we all know that these are both very good heads.
Now, for my application with a smaller cam (tr 224 224 112+4), which one is going to give better low rpm response/torque for the street? My car will be a street car and I would rather not give up much bottomend torque if I don't have to.
Is the smaller-runnered afr 205 going to be significantly better on the bottomend/street than the larger-runnered tfs 215 or will it be not noticed? Is the larger cross sectional area of the tfs heads compensated for by their smaller valve angle to give similar low rpm response?
This is the only obstacle in my decision on picking heads, so any help would be appreciated.
Does anyone have first-hand driving experience with both types of heads?
i would go with the 205's,you def dont need a big port,i love the trickflows but i think the 205 is better for what you want,plus you need roller rockers for the trickflows
You are choosing between two excellent heads. I don't personally think you are going to see a huge difference between the two heads. What I would consider is customer service and other factors than the final hp you might achieve with either head. In all honesty, TFS hasn't had a major issue since they were introduced but they have also been on the market for less time than the AFR (LSx version). AFR ran into an issue with soft valves about a year or so ago. They put a public announcement out on this board and several others stating they would fix any head that ran into the problem, which they have since done. For an aftermarket company to state publicly they had an issue and were fixing it when you think about how long many companies warrantee performance products was a testiment to their customer support.
Another point to consider is AFR (Tony) is on this board every day answering questions and helping guys get the most from their setups. To me the answer would be based on several factors, with final dyno numbers only being one of them. I am removing my Darts in the spring, my AFR's arrive tomorrow so I guess you can figure out what I decided to do.
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
mill them .024 and your car will move.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I give you a guarantee in writing our 6016 cam (224/228 .581 lift) is worth an easy 10 RWHP over the cam you have with no other changes and the exact same if not better street manners.
At $395 thats only $40 per pony.....I would strongly consider it. My "air dyno" may even be light at ten horses. Its going to carry the torque out the back significantly better....thats how the additional power will make itself available to you.
Tony
Tony
Thanks Tony for your input.
I guess no one has direct hands-on experience with both of these heads on similar setups concerning bottomend power and torque. You'd think by now there would be some direct comparisons but I guess not.
AFR has great customers service and other intangibles - probably be wise to go with them just for that reason.![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
I had similiar questions heres a great thread https://ls1tech.com/forums/generation-iii-internal-engine/732392-recipe-500-rwhp-heads-cam.html
I will say its not too much because tuners have milled more than that and have installed the much bigger G5x-3 cam. but as always, have it double checked before starting it.
I can vouch for this as I have this exact cam in my car with the 205s. Well designed combination hands down. Do it right the first time and go with this cam. Smooth as hell inside the car yet has a nice lope sound outside. Pulls hard as f@#k!!
