need help dowel pin
Old Jan 28, 2008 | 02:53 PM
01BlackCamaroSS's Avatar
Default need help dowel pin
i pulled my head of back in november so i could re thread the header bolt holes and i am just now getting around to it, i have a few problems tho, one i lost one of the dowel pins and have looked every where for it, is it that big of a deal can i get away with using just the one alignment dowel, and if not where can i find one, my second problem is there is water in the head bolt holes that turned to ice any suggestions on how to get the ice out thanks
Old Jan 28, 2008 | 03:17 PM
i have been looking online trying to find any place that has these but i cant and i need them asap
Old Jan 28, 2008 | 03:24 PM
itslow's Avatar
LS: GM P/N 12570326 - $3/ea @ SDPC
BBC: GM P/N 12558081 - $1.60/ea @ SDPC
The BBC parts are a tad shorter, but work fine. I'd suggest checking with your local parts stores (ie: NAPA) or GM dealer.
Old Jan 28, 2008 | 03:31 PM
will the ones for a sbc work
Old Jan 28, 2008 | 03:33 PM
Russ K's Avatar
Getting the ice out of the bolt holes is the least of your problems. If you didn't remove the coolant drain plugs from both sides of the engine, that water is now frozen. This can crack the cylinder block.
Russ Kemp
like an an old tpi engine
Old Jan 28, 2008 | 03:34 PM
what do you mean the engine coolant is frozen??
Old Jan 28, 2008 | 03:44 PM
Russ K's Avatar
If you had just water in the rad, then you removed the heads without draining the block, and some of the water ran into the head bolt holes and then froze. Then the same water that is in the engine is also frozen which can crack the block.
Russ Kemp
Old Jan 28, 2008 | 04:00 PM
no i have antifreeze in the radiator, the water dripped down from the hood cowl and got in the bolt hole or from snow melting
