how big to go???
Old Feb 5, 2008 | 06:44 PM
Gregorya24's Avatar
thanks man, i will take a look at the torquer
Old Feb 5, 2008 | 07:05 PM
'02SOMz28's Avatar
tsp torquer 2 or the 231/237 have been known to be within 400 and up to 420 hp range cams with full bolt on's...
Old Feb 5, 2008 | 08:49 PM
Gregorya24's Avatar
thanks thats the answer i was looking for........what kind of mpg do yall get the torquer?
Old Feb 5, 2008 | 08:58 PM
99z28monster's Avatar
streetable is MOSTLY in the tune. If you have a good tuner you have alot of options if not get something proven. Actually the cam I am currently running is the thunder racing Cheater cam. It has made over 400hp cam only but not much over 400. specs are 214/230/.601 117lsa very sneaky cam. However its main purpose is stock exhaust cars but the ones that have made over 400 had full bolt on and m6 cars.
Old Feb 5, 2008 | 09:07 PM
SOM02WS6's Avatar
I DD mine as well with a 232/238 .595/.605 112LSA XE-R lobe.. I have some stock heads that were PP other than that full bolt ons and put down 430...
Old Feb 5, 2008 | 09:13 PM
Gregorya24's Avatar
Nice thanks guys...i think i have chosen my cam!
Old Feb 5, 2008 | 10:01 PM
noah89's Avatar
I've got a 224 as defined in my sig. There's a dyno graph buried in TA Pics. This is through cats and a 12 bolts with 4.11's.
Old Feb 5, 2008 | 11:45 PM
chrs1313's Avatar
got a 230/230 cam only with an a4...can be done with a daily driver...mine has amazing street manners almost close to when it was stock...also did i mention 422rwhp
Old Feb 6, 2008 | 12:09 AM
'02SOMz28's Avatar
What is your choice????
Old Feb 6, 2008 | 06:35 AM
Gregorya24's Avatar
torquer v2, but i havent decided on what lsa yet
Old Feb 6, 2008 | 10:17 AM
ABQ99TA's Avatar
Call TSP and talk to them they are very helpfull.
Old Feb 6, 2008 | 09:47 PM
  #32
SLP Firehawk's Avatar
go with the 112 dude you will not regret it i talked to jon from TSP for a while and he said that 112 will make it sounds real good and perform like a beast. i just put my cam in and it sounds amazing i dont know how the power is yet its only been in for a couple of hours
Old Feb 6, 2008 | 10:02 PM
  #33
taws6m6's Avatar
Quick question guys, i am looking into the v3 rite now as a cam swap. ABQ99TA your running the v3 and you put down 404/374. 02DOUBLEUS6 is running a v2, and is putting down 413/391. Whats the reason for this?? Is this all in the tune here? Is it the difference in the heads cause of the years of cars?
Old Feb 6, 2008 | 10:08 PM
  #34
COOKIE MONSTER's Avatar
Originally Posted by CODE4LS1
still need heads I think
Nope, you could get those number from an F14 cam...
Old Feb 6, 2008 | 11:27 PM
  #35
ABQ99TA's Avatar
It could be many things, tune,dyno,gears,rims,tires. I know I'm running cats and that will take close to 10 rw out and I'm not on stock gears anymore.
I think they are both good cams, I belive the V3 will have a little longer pull.
My dyno graph looks sweet if I new how to post it I would. There are too many factors to care to much about 9rwhp when the cars don't have the same boltons and were tuned by different poeple aswell as the dyno its self.
Good luck with you cam either way you will love it.
Old Feb 7, 2008 | 03:37 AM
  #36
WLDLS1's Avatar
I Would Use A 224/230@114. Nice Cam. Good Power.
Old Feb 7, 2008 | 08:52 AM
  #37
PREDATOR-Z's Avatar
Custom
Old Feb 7, 2008 | 07:53 PM
  #38
chrs1313's Avatar
Originally Posted by PREDATOR-Z
Custom
i agree 100%
Old Feb 7, 2008 | 08:28 PM
  #39
Mike454SS's Avatar
I want 450 RWHP from a completely stock engine with completely stock driveability...can I look at it sternly next time I open the hood and say "HEY...MAKE MORE POWER" and have my goal?
I'm not trying to be an ***...but thats how your question reads to me. YOU need to define your idea of streetable first, THEN you can probably make a better decision on how much cam you want to run.
The only way I can see to make more power than a stock F-Body LS1, and retain COMPLETELY STOCK as it left the factory ENGINE reliability (I say engine cause you'll probably break the axle, stock clutch won't take it...blah blah blah), is installing a new stock crate engine from GM. You want LS7 power, install an LS7, you want LS2 power, install an LS2...you want LS3 power...you get the idea...once you get into aftermarket cam's and such, something changes. You can have dam good streetability...but it's never quite as nice as a "stock" grind will be. The way I see it, everything behind the engine can be beefed up WITHOUT sacrificing driveability, including the clutch (if you spend enough money)...but unless you want to spend a LOT of money, you FIRST need to define what you're willing to compromise with the engine.
Old Feb 7, 2008 | 10:20 PM
  #40
allthrotle's Avatar
I made decent power and I feel that I didnt sacrafice any drivability from stock. I dd my car in the rain, snow, and sun. I bought the car bone stock down to the filter drove it for about 5k and decided I wanted more, I have since done all the mods listed in my sig and I think it still drives as close to when I had it stock.
