OK, tried searching, no luck.. Need to pick some stealth cam specs
224/222 .612/.588 114+2LSA
That is a -5* overlap, Stealthy with the right exhaust, should make 390+ and a shitload of trq if installed properly (Degreed with proper preload)
I run the same on my 6.1L but on a 117 LSA and I'm pumping 450rwhp out of it H/C
This is a Custom grind, Comp Cam
