flycutting for a tspv3??
Old Feb 6, 2008 | 09:38 PM
taws6m6's Avatar
Default flycutting for a tspv3??
Just like it says, is flycutting needed for this cam with stock heads? specs are 231/234 .643/.598 01ws6
Old Feb 6, 2008 | 09:41 PM
waterbug1999's Avatar
What kind of LSA is that?
Old Feb 6, 2008 | 09:46 PM
taws6m6's Avatar
111lsa
Old Feb 6, 2008 | 09:51 PM
Is it a vendors grind or just one you threw together? Maybe the TRAK?
Old Feb 6, 2008 | 09:52 PM
chuckyt1's Avatar
My guess is it will fit. Would I run it with out checking? NFW... I put in a 243/248 on a 110 and PTV was almost nill... You have an M6, which means you need to be carefull...
Old Feb 6, 2008 | 09:54 PM
I think its a cam from TSP... Here it is. Best advice is to conatct them via thru here or a phone call and ask them. I know they have ran that cam with all different combos.
http://www.texas-speed.com/shop/item...d=669&catid=44
Old Feb 6, 2008 | 09:56 PM
COOKIE MONSTER's Avatar
Hmmm I don't know with a lift like that... I'm starting to think the LS1 heads are only good to .600 lift MAX. However, I know you'd be fine with LS6 heads
Old Feb 6, 2008 | 10:11 PM
chuckyt1's Avatar
Duration is what kills you, not lift...
Old Feb 6, 2008 | 10:16 PM
taws6m6's Avatar
hmm it comes with a 112 also
and it is not a custom grind, its just a tsp cam i have been looking at
Old Feb 6, 2008 | 10:34 PM
MdFormula350's Avatar
plenty people rock that cam in stock headed ls1s should be no problems
their bigger ms4 cam fits fine as well
"Magic Stick V.4 239/242, .649"/.609" Camshaft With Your Choice of Lobe Seperation (111 LSA Standard)
The Magic Stick V4 camshaft is Texas Speed's premier LS1 camshaft!
The MS4 camshaft is the result of extensive engine dyno testing & research! Engine dyno results have shown over 80 horsepower gains with no other changes on a stock 2001 LS1 engine!! "
the torquer 3 is widely used
"All New Torquer v.3 Camshaft!
231/234 .643"/.598" 111 LSA
*Requires Aggressive Double Springs!
2300-6700 RPM Power Band with a peak around 6400rpm; This is an excellent performance camshaft with a rough idle! Custom tuning required"
Old Feb 6, 2008 | 10:40 PM
Asmodeus's Avatar
lol I knew when I saw the topic someone would make a post like this. I hope you aren't implying max lift has anything to do with PTV clearance. And I hope you aren't implying he's going to see .643 or w/e valve lift when you take hydraulic lifters and pushrod deflection into consideration.
And what makes you think LS1 heads are only good to .600 when LS6 heads are good for more? Can you post the flow sheet numbers you're referencing?
Old Feb 6, 2008 | 10:46 PM
taws6m6's Avatar
Sorry man, i am new to this. But max lift has nothing to do with PTV clearance? Right? At all? PTV clearance has to do with the lsa?
Old Feb 6, 2008 | 11:05 PM
Asmodeus's Avatar
Nope, at max lift the piston is down in the bore, it wouldn't make sense to have the valve at full lift with the piston coming back up would it? But it WOULD make sense that with the piston coming up to the top of the bore, the valve has not closed completely yet.. which is time off the seat.. which is duration.. and LSA and advance determining valve events.
Old Feb 6, 2008 | 11:09 PM
ABQ99TA's Avatar
I have this came and it rocks. I talked to TSP and they said it was fine on stock heads.
They also said it dynoed 7hp less than the MS4 during testing. Mine is on 111 lsa
taws6m6's Avatar
ohhh, thanks man i am learning. so fly cutting wouldnt be an issue with this cam right? I know i see many people running it
Old Feb 6, 2008 | 11:11 PM
Asmodeus's Avatar
It shouldn't be an issue with stock valves and stock compression. Change those and you have to check.
Old Feb 6, 2008 | 11:15 PM
Like I said above... Call or PM TSP and see what they recommend. Or try a search and see what others have done.
Old Feb 6, 2008 | 11:16 PM
taws6m6's Avatar
hey ABQ99TA, i asked you a question in another post, i think it was the how big to go post or something, u didnt catch it. Anyway, i saw a member that was running the tspv2, and he was dynoing more than your setup, both bolt on cars, is this due to the tune? Or maybe the different years of cars(different heads)? Not trying to be rude or anything, just trying to understand why? Does the v2 typically put down more? I thought the v3 was a bigger cam
Old Feb 6, 2008 | 11:17 PM
https://ls1tech.com/forums/showthrea...hlight=231/234
https://ls1tech.com/forums/showthrea...ight=231%2F234
Old Feb 6, 2008 | 11:25 PM
Asmodeus's Avatar
They were different dyno's. End of story. One thing you cannot do with dyno's is compare different ones to the same standards. You use dyno's for tuning purposes and that's it. And you use the same one every time or you'll be all screwed up. (though in a sense you can re-baseline if you do move to another one. Just don't baseline somewhere, mod, then test it somewhere else, you'll find out exactly nothing.)
