realistically cam swap price?
http://www.thunderracing.com/catalog...mid=32&sid=526
This is the Crane tool, I think its what socmguy was referring to.
Restricted User
yeah, that's the one. THanks.
Don't forget how much the tune will be. Mine was done by Ryan at Ryan's Performance Machines. He's the man! Hit the 400 mark w/ a torquer 2, and bolt ons through 4.10 gears! M6 of course.
FWIW, the crane valvespring tool is definitely worth every penny. What kind of RPM's are you wanting to turn? Stock lifters should be fine, and turning too high with stock internals isn't much of a good idea to start with.
LS1TECH & Trucks Sponsor
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
well LS7 lifters arn't much and are added insurance... ya i dont like the idea's of spinning stock motors high 6500-6700 is about right I shift my dad's 06 c6 @ 6500 it seems to like that plus any cam i picked would have to a 3000-6500 one for mid/high power so its really street able
__________________
__________________
#37
well lets see how mine has added up
Parts ordered from TSP
cam dual spring and pushrods $710
ls2 timing chain $36
cam swap gaskets $44
shipping $26
TOTAL $817
Had to return pushrods because i got the wrong length ADD $9 for me shipping them back
Parts ordered from thunder racing
melling oil pump $149
valve spring compresser $129
$10 order on line discount
Shipping $11
TOTAL $280
the oil pump was on back order so they sent out the spring compresseri got billed $130 . it was the wrong one, so i paid to send it back ($5) then they sent the oil pump out i was billed $160, then the refunded me $120 for teh spring compresser.
bottom line i spent $175 for the oil pump
Other parts bought and ordered
crane spring compresser from advance auto (online) $117
dowels $6
oil $5 just need 1 qt
anti freeze $12
gallon of water to mix with antifreeze $1
lock tight $5
NGK tr 55 plugs $18
pulley install tool $44
Brake clean $5 (2 cans)
retune $80hr
give my friend $50 for leting me use his place
GRAND TOTAL SO FAR $1344
"i will update if i remeber some thing i might have for got"
shipping $26
TOTAL $817
Shipping $11
TOTAL $280
dowels $6
anti freeze $12
lock tight $5
NGK tr 55 plugs $18
retune $80hr
#38
Just get a heads and cam kit from TSP. In the long run you'll save money and they have some great budget heads as well as cams. Considering I believe John R or Matt there is making 465 to the rear wheels with a fast 90/90 the i think a MS3 and some heads, ported oil pump, new lifters, gasket kit, pushrods, double roller timing chain. I think he'll take care of you.
#39
comp cam $330
pac springs $150
comp pushrods $120
ls2 chain $40
water pump gaskets $20
ls6 oil pump $130
oil and filter around $40
for a cam swap total of right at $830....if things had gone right
instead add in $120 for being ripped off on valvesprings, $40 for used lifters cause the stock cam was bad and chewed a couple up, $80 head gaskets, $80 head bolts, $50 head surfacing
so in the end it cost me $1160...well add another $130 if you count I ended up getting a set of centerbolt heads because I thought one of mine was warped...so $1290
kinda wish I hadn't added all that up now
pac springs $150
comp pushrods $120
ls2 chain $40
ls6 oil pump $130
