high rev how to
Old Feb 8, 2008 | 11:55 PM
jkwalkercchs's Avatar
o yeah dude i planned on buying the baddest tranny finishline or performabuilt has
but tranny and stall will be last thing on my list
Old Feb 9, 2008 | 12:12 AM
frated420's Avatar
Originally Posted by SS101
at 7K your probably gonna need shaft mount rockers...depending on your heads, jesel makes the best shaft mounts i know of, they come in a few flavors and have a series of especially lightwieght ones but they're priced accordingly. in any case, you need shaft mount rockers if you want to hit 7k continuously AND with streetable reliability (longevity). hydraulic should be fine as long as you keep it at or very near 7k.
Yella Terra rockers are shaft mount, they are holding up to over 1K at the flywheel on our boosted street vette.
Old Jul 15, 2008 | 02:16 PM
GrannySShifting's Avatar
Stumbled across this looking to price some rockers to sell, not sure where your getting this from but 7K+ rpm is not crazy voodoo necessary.
Weve turned hyd stuff to 8500 rpm with stock rocker bodies, and my stock bottom end has pulled to 7500 with stock rockers, stock lifters etc. Right spring/cam lobe gets her done. Dont chose to go less stroke, less stroke is less power period. 4.1" stroke sings just fine at 8000 rpm. Destroking something is for when the rules make you
Old Jul 15, 2008 | 02:22 PM
99blancoSS's Avatar
Thumbs up
Not enough emphasis gets put on this.
Old Jul 15, 2008 | 02:36 PM
murt's Avatar
with that in mind what should i look for in a spring to build a street/strip valvetrain for the tsp 233/239 cam
Old Jul 15, 2008 | 04:36 PM
porsche914ls6's Avatar
How heavy is your car? I would think a peaky high rev motor would not serve you well unless you are weighing a whole lot less than stock. If you have a gutted race car that weighs less than 3000 lbs, go for it...I'm thinking you will need all the torque in the world to get that Camaro/Firebird or Vette out of it's own way. High rev motors sound cool and all but be careful to build the correct type of powerplant to get you to your goals.
Old Jul 15, 2008 | 09:05 PM
KCS's Avatar
KCS
Moderator
Don't try to re-invent the wheel. The fastest naturally aspirated guys are turning about 9500RPm with a 4.00 stroke.
Just keep it simple, and enjoy the power AND reliability instead of changing springs with every oil change.
