Patrick G cam!!!
Old Feb 13, 2008 | 03:55 PM
SlowZ28/SS's Avatar
I actually just bought my stall converter about 10 mins ago. 5200 should do.....curious to see how it acts on the pro trans brizake! Shane at thunder racing just called me and we got everything set up. Cam, pushrods, valvesprings, and my ARP pro series rod bolts Only have two things left to buy before I'm done. Should be finished in less than two months...tuning and all.
Old Feb 13, 2008 | 04:56 PM
david vericker's Avatar
Originally Posted by SlowZ28/SS
Thanks skyhighsami, i'll keep that in mind. Its still cold though, so waiting a month might not be to bad. Is there anyone else here running a high lift cam on the street like this? If so, how are the street manners?
My cam has a fair amount of lift and duration,but it is not nearly as radical as your cam. The street manners are good, but a 114 + 4 vs 109 + 2 makes for a whole lot of differance when talking about streetability.
Old Feb 13, 2008 | 06:13 PM
SlowZ28/SS's Avatar
Yeah i hear ya....but its gonna sound killer at least, even if it turns out to be a turd...which wont happen. lol. What kind of times is your vett running?
Old Feb 13, 2008 | 06:34 PM
sevanseriesta's Avatar
I Like the sounds of that cam.....Can't wait to hear it idle, should be sick
Old Feb 13, 2008 | 07:03 PM
SlowZ28/SS's Avatar
Maybe if it does well they'll call it. Trex big brother ...lol.
Old Feb 13, 2008 | 08:00 PM
chrs1313's Avatar
what kind of internals are you running with this cam to spin it to 7300...
now that is what i call a max effort cam...
Old Feb 13, 2008 | 09:06 PM
SlowZ28/SS's Avatar
Only thing not stock in the engine is the ARP pro rod bolts for extra strength....other than that.......welll, thats it. After I try hitting my goal n/a i'm going to put 100 on top and try to dip into the 9's....after that, i'm getting rid of it and building something else. Dont ever keep any car long, just seems so awesome building new ones...but maybe thats just me .....
Old Feb 13, 2008 | 09:55 PM
98RedZone's Avatar
I run a LSK lobe on the intake with that lift, but nowhere near that duration. I can't wait to hear your idle, not exactly gonna be a sleeper!
Old Feb 13, 2008 | 10:16 PM
patriotformula's Avatar
Thats GOTTA hit the pistons... My MS4 on a 113 with less lift and a 111 LSA almost hits!
Old Feb 13, 2008 | 10:47 PM
jitsumania's Avatar
10 Second Sleeper Club
My Z's motor has Patrick G's fingerprints, handprints, etc (cam included) all over it and it just screams. This man knows what he is doing for sure!
Patrick G cam in my ride: 238/242 duration at .050, .605/.610 lift, 112 LSA +3 installed at 109 intake centerline.
A4 with performabuilt level 2 tranny with a Yank 3600 stall
This car is my daily driver and track car on occasional trip to track (yet to occur on my new setup).
Old Feb 13, 2008 | 11:10 PM
I dont doubt Patrick G... just from experience... my old motor spun a bearing and that clearance (on that spun rodbearing) made my valve smack the piston. How thick is a rodbearing?
Old Feb 13, 2008 | 11:26 PM
  #32
ssfast99's Avatar
people get so scared about valve to piston clearence when they dont realize that joe from t56 rebuilds has a cam bigger then what is stated up above. my t-rex was on milled stock ls1 heads spinning to 7200 and never had a problem. let us know what happens and have fun.
Old Feb 14, 2008 | 01:00 AM
  #33
ThaBirdMan's Avatar
Very large...should be interesting.
Old Feb 14, 2008 | 05:46 AM
  #34
KONG's Avatar
Well guys I decided to get Patrick G to spec out a cam for my car. Lemme know what you guys think of this!
240/248@.050 .649/.656" 109LSA+2advance
This if for my cam only car with bolt ons. Goin for low 10's!!!!
Why do you think you need a cam that big to run 10's???
Old Feb 14, 2008 | 06:17 AM
  #35
Ari G's Avatar
what Heads and Exhaust do you have?
Old Feb 14, 2008 | 08:13 AM
  #36
SlowZ28/SS's Avatar
Its a cam only set up...stock everything and no nitrous. My goal is very low 10 with weight reduction and a high auto stall. Going for the record this year with a cam only set up. Talked to shane at thunder racing for about 45 mins the other night. Gave me some pretty good advice to. Not saying that I dont know what i'm doing but i just think he has more experience. I'm only 23 but i've had an s-10 that i've dragged since i was 16, it's now in the 9's, hopefully 8's this year.
Old Feb 14, 2008 | 08:21 AM
  #37
KONG's Avatar
Did he also explain the necessity of having a well set-up suspension??
Old Feb 14, 2008 | 08:25 AM
  #38
SlowZ28/SS's Avatar
yes yes....but remember, i have a s-10 in the 9's on a 10.5 tire. I think i'll be ok on the suspention aspect of it. Gettin a s-10 to hook off a 5000 stall is like getting a grocery cart to hook up with a small block in it. On a serious note though, we did talk about it for a while, Car already has Qa1 all the way around it. Still have some small stuff to do under it though.
Old Feb 14, 2008 | 09:16 AM
  #39
KONG's Avatar
Ha Ha.. I can only imagine. I definitely wish you luck and have fun.
Old Feb 14, 2008 | 11:14 AM
  #40
SlowZ28/SS's Avatar
Thanks a lot KONG. I'll need all the luck I can get.
