Patrick G cam!!!
Old Feb 12, 2008 | 08:19 PM
SlowZ28/SS's Avatar
Default Patrick G cam!!!
Well guys I decided to get Patrick G to spec out a cam for my car. Lemme know what you guys think of this!
240/248@.050 .649/.656" 109LSA+2advance
This if for my cam only car with bolt ons. Goin for low 10's!!!!
Old Feb 12, 2008 | 08:24 PM
HEMIETR's Avatar
Good luck.
Old Feb 12, 2008 | 08:26 PM
SlowZ28/SS's Avatar
Thanks, cant wait to get this back from thunder racing and install it. Should sound pretty radical!
LS1curious's Avatar
Better check that PtV good luck getting it to idle.
Old Feb 12, 2008 | 08:29 PM
sick240's Avatar
we will need a sound clip when all said and done. would like to hear it idle.
SlowZ28/SS's Avatar
lol...i dont want it to idle. Pat said it should clear on the PtV but to double check it. Even if it dont.....i'll make it
Old Feb 12, 2008 | 08:33 PM
LS1curious's Avatar
You better check that piston to valve. Its gonna be close to .010 into the piston with that ICL.
Old Feb 12, 2008 | 08:40 PM
SlowZ28/SS's Avatar
Yeah...if i can get it to .040 i'll happy. I know thats still close but I have to other engine that are similiar to this PtV. One is 600hp and the other is only 400hp. Havent had any probs out of them yet through 2 season.
Old Feb 12, 2008 | 08:57 PM
socmguy's Avatar
Restricted User
Good luck with your goals. You must be putting the car on a serious diet!
Old Feb 12, 2008 | 09:00 PM
SlowZ28/SS's Avatar
Oh yeah....major diet and a huge stall. I'll post up idle clips in a couple weeks or so.
Old Feb 12, 2008 | 09:03 PM
hammertime's Avatar
Old Feb 12, 2008 | 09:04 PM
01 BERGER CAMARO SS's Avatar
damm, nice grind.
Old Feb 12, 2008 | 10:13 PM
Ryan'sSS's Avatar
Good luck with your cam. I havent seen anything bad about Patrick G specd cams. Actually I just got one myself. The one down fall was it took TR a month to get it to me.
Old Feb 13, 2008 | 06:47 AM
SlowZ28/SS's Avatar
Wow...were they on a major backorder or what? Hope it dont take that long with mine
Old Feb 13, 2008 | 06:54 AM
skyhighsami's Avatar
no title here
If they are on that much of a back order I have a cam of similar duration for sale. PM if you cant get it from them in a timely manor.
Old Feb 13, 2008 | 08:03 AM
SlowZ28/SS's Avatar
Thanks skyhighsami, i'll keep that in mind. Its still cold though, so waiting a month might not be to bad. Is there anyone else here running a high lift cam on the street like this? If so, how are the street manners?
Old Feb 13, 2008 | 08:27 AM
ss1's Avatar
ss1
Hummfff...Him go big! Stock 346 with stock heads? How high are you gonna turn it?
Old Feb 13, 2008 | 11:09 AM
SlowZ28/SS's Avatar
Patrick said to set the rev limiter at 7300....so i guess 7299
Old Feb 13, 2008 | 02:13 PM
JPH's Avatar
JPH
26* of overlap @.050=she will be a THUMPER! A4 car use atleast a 4400+ stall.
Old Feb 13, 2008 | 02:58 PM
bad2000z's Avatar
Dayum! I'll be following your progress.
