TSP heads and cam
LS1Tech Premium Sponsor
Guys let me help clear up some confusion in this thread.
The ms4 requires no piston modifications with the stage 1 ls6 head. The stage 1 ls6 head actually has a little bit better than stock p/v even with the chambers set at 62cc!!
The stage 2.5 ls6 & stage 2.5 5.3l head will not clear the Magic Stick 4 camshaft. The MS4 is just a little bit to tight for comfort. I'm working on a solution for that, but you guys are going to have to give me some extra time!
From a spring life standpoint I've seen springs with 50k miles on LSk lobes that still held pressures pretty well. I'd say shoot for swapping springs ever 40k miles or so & you should be in great shape!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
it seems like every one here is worried that the MS4 is too big and wont make as good of power as maybe a smaller cam would
wouldnt it be better to get gears as well im no expert but i thought about getting a t-rex cam but allot people said that without gears i wondent gain *** much power as if i were to go with a smaller cam and my car is a DD and ive never driven a camed car so multiple people said to go with a smaller cam get used to that and save money for gears then go with a t-rex so now ive decide to go with the tsp t2 cam
