heads
Old Feb 19, 2008 | 06:24 PM
discostu's Avatar
Default heads
i know this is a camaro spot. but you guys help alot of people in the info department so here is the problem. i have a buddy building a low compression 454 for a nova. He is wanting 600ft lbs and 600 horse i am just looking for a manufacturer that produces around 190cc runner heads. but the heads also need to be able to hold a .800 lift. he wants to run pump gas. he says this size will have torque down low for the launch. any help will be welcomed
Old Feb 19, 2008 | 06:35 PM
QuickSilver's Avatar
190cc runner on a BBC not happenening.
smallest offered by trickflow is 280 and those are an oval port they make great power though.
Josh
Old Feb 19, 2008 | 06:39 PM
discostu's Avatar
i did not understand the concept of such a small runner but that is what he said he needed. so i told him i would try.
Old Feb 19, 2008 | 06:42 PM
THEBRAD's Avatar
u gave small block runner size for a big block. is it a small block or a big block? cause i know world industries makes 454 small blocks soo?
Old Feb 19, 2008 | 06:47 PM
discostu's Avatar
all he stated was 454. i am most certain he found it in an old truck so i would say big block.
Old Feb 19, 2008 | 08:22 PM
THEBRAD's Avatar
a 454 can make 600hp 600lbs with less than .800 inch lift on the cam and i would also highly recomend no having that much lift on a small intake runner cause more than likely he'll have a good amount of duration on that big of a cam and the heads wont flow enough to take advantage of it. but if he wants a head good to .800, id suggest brodix heads, either the BB-2 PLUS(312cc intake runners) or the BB-2 XTRA(365cc intake runners). they run between 1000 and 1200 a piece
