is this a good deal on a set of 243 heads???
Old Feb 19, 2008 | 10:34 PM
CaMaRo67RS355's Avatar
Question is this a good deal on a set of 243 heads???
01 Z06 40,000 mile 243 heads stock $350 + Shipping...
should i jump on them or what?
Old Feb 19, 2008 | 11:18 PM
BayAreaSS's Avatar
I would jump on that
Old Feb 19, 2008 | 11:23 PM
tatasta's Avatar
jump!!
Old Feb 19, 2008 | 11:25 PM
rickyracer25's Avatar
See you at the bottom jump
Old Feb 19, 2008 | 11:29 PM
jetlag's Avatar
I agree, and shipping shouldn't cost more than $50...I've seen several pairs of heads and its usually been around 40-45. (but that was for SOHC heads, that might weigh a little more)
Old Feb 19, 2008 | 11:56 PM
Raptor_WS6's Avatar
go for it, if not send me the info cuz i will
Old Feb 20, 2008 | 12:25 AM
LebaneseShowoff's Avatar
Seriously, i've been looking for these for quite a bit now.
Old Feb 20, 2008 | 02:28 AM
PREDATOR-Z's Avatar
With the light valves Yes it is a good deal, just make sure they are not LS2 heads otherwise you can get a brand new set for 400>450$$
Also just FYI you'll need to get those LS6 heads refreshed, seats/seals springs, valve guide check and valve job. Soooo a brand new set of LS2s from Patriot (Gunnar) would be cheaper after all.
Old Feb 20, 2008 | 06:47 AM
all i know is they came off a 01 Z06 with 40,000 miles and havent been used since. he was going to use them on his t/a but things didnt work out...
Old Feb 20, 2008 | 07:02 AM
black01_WS6's Avatar
if he goes 350 shipped then it would be a good deal. In stock form they really are not worth too much more.
Old Feb 20, 2008 | 07:36 AM
PREDATOR-Z's Avatar
They would still need to be refreshed, which is additional $$
If you plan on doing so get them, but like I said you can get BRAND NEW LS2/LS6 243 castings fron Gunnar at Patriot for less than refreshing those. They are the same heads just different valves.
Old Feb 20, 2008 | 08:34 AM
01Z0H6's Avatar
Sounds like a no-brainer to me...
Old Feb 20, 2008 | 08:58 AM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
They are LS6, not LS2, those valves are worth some $$$. You can get some cheap deals out there on new sets of heads, but not with those valves
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Feb 20, 2008 | 11:11 AM
vtirocz's Avatar
Scoggin Dickey They are LS6, not LS2, those valves are worth some $$$. You can get some cheap deals out there on new sets of heads, but not with those valves
Today 09:34 AM
You sure on that? I thought the 01 LS6 heads did NOT come with the lightweight valves, only the '02-04 did.
What's the difference between '01 LS6 heads and LS2 heads?
Old Feb 20, 2008 | 11:51 AM
I didn't read the 01 Z06 part, you are correct. They aren't anything special in that case. 243s are still great heads, but without the benefit of the 02-04 valves I'd look into something else
__________________
Old Feb 21, 2008 | 12:28 AM
PREDATOR-Z's Avatar
Just contact Gunnar at Patriot Performance. Tell him you want a stock set of LS2 243 casting heads. If you plan on camming the car, you can get them with duals at extra cost but Gunnar will install them for ya.
