changing out the stock cam for a stock cam?
take the free cam if you want to try it. springs are not a waist of money like noted above, comp 918 springs improve peak power and rpm on a stock cam over worn stockers, heads and intake do not need to come off, all gaskets are reusable unless you tear one up in the process, one of the esiest cam changes to do. i say give it a whirl and try to find some 1.8 rockers on the cheap to go with it.
OK.... you don't want to have to smog test? Try the 2002 LS6 Cam and LS6 Springs.
GM says the springs will last 100K and it will idle and drive like a stocker. You will probably get about 20-25HP more.
this is a complete waste of time. by the time u pay the labor to swap springs and the cam its not going to be cheap. ur going to spend another $500 to do it right. talk to jeremy over at mph (u know jeremy) about the cam he put in fat chris' car. made a huge chunk of power and u couldnt even tell it had a cam.
I agree, its a complete waste of time. I would not go with anything smaller than a 224/224. If you cant afford to change valvesprings or get tuning after a cam swap, I suggest you not even attempt it. You should really save up and get a nice cam (at least 228/232 range). The way tuning has advanced you can run a really nice size cam and it will start, drive and idle completely streetable.
Location: Your girl's back door giving her the long stroke while you're at work
Don't waste your time.
FYI: here are the specs on the stock 98-00 and 01-02 cams
stock 98-00
duration@.050 198.86 intake 209.25 exhaust
lift .498 intake .497 exhaust
LSA 119.45
stock 01-02
duration@.050 196.37 intake 208.72 exhaust
lift .464 intake .479 exhaust
LSA 115.92
stock 98-00
LSA 119.45
stock 01-02
LSA 115.92
