spray
Old Feb 21, 2008 | 11:15 AM
PowershifterNC's Avatar
Default spray
how much can I safely spray my stock ls1 w/117k?
Old Feb 21, 2008 | 11:26 AM
jcolews6's Avatar
I sprayed 150 on my old 140000+ motor and it still ran perfect. Just use the safety equiptment.
Old Feb 21, 2008 | 01:54 PM
SSmoken's Avatar
120k here with a 100shot. anywhere between 100-150 and you'll be fine.
Old Feb 21, 2008 | 02:01 PM
landonew's Avatar
wrong section. should be moved to the nitrous section. Look at the sticky in the Nirtous section
Old Feb 21, 2008 | 02:10 PM
gold98Z28's Avatar
wet or dry? wet i spray 175 flywheel,152rwhp. do you or are you planning on or have the capability to pull timing, if not 125shot is all i would do without pulling timing, just need good gas.
Old Feb 21, 2008 | 02:13 PM
stevied916's Avatar
read the stickys in the nitrous forum
Old Feb 21, 2008 | 09:10 PM
speedshifterNC's Avatar
thnx...
Old Feb 22, 2008 | 04:40 AM
machete's Avatar
yup 125shot here and ive got 140,xxx on the clock.hitting 11.7
