224r vs TR224
Old Feb 22, 2008 | 02:53 PM
kingsey's Avatar
Default 224r vs TR224
I know they will be very close only thing the tsp has a higher lift. Any thoughts welcome
Old Feb 22, 2008 | 03:29 PM
socmguy's Avatar
Restricted User
the lobes also may be different
Old Feb 22, 2008 | 04:28 PM
BIG_MIKE2005's Avatar
Straight from TSP's site:
This camshaft features Comp Cams XER lobes! The XER lobes have been proven to make big horsepower & torque thanks to their aggressive ramp rates & healthy lift.
1400-6300 RPM Power Band
This is the cam I run & am very happy with it.
Old Feb 22, 2008 | 05:32 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
The XeR lobes are designed to increase the 'area beneath the lift curve' in each profile. They begin moving the valve off its seat quicker, to initiate flow earlier. This basically makes the XeR cams function like a much 'bigger' cam (greater duration) yet they increase low-end and mid-range torque in the most often used rpm range. Horsepower and torque output are enhanced throughout the entire rpm range.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Feb 22, 2008 | 08:40 PM
kingsey's Avatar
Lots of views no posts. If i didnt post this from my blackberry i woulda added a poll. Up for the night
Old Feb 22, 2008 | 10:28 PM
Hell'sChariot's Avatar
I love my TR224.
Old Feb 23, 2008 | 01:39 AM
35th SS's Avatar
tr224 here also.happy with it.
Old Feb 23, 2008 | 03:13 AM
z28ss4me's Avatar
Love my TR224, nice HP and Tq and easier on the on the valvetrain then the TSP, i can't imagine the TSP makes much more HP then the TR224, if it makes more at all.
Here's my dyno sheet...mods in sig:
http://home.comcast.net/~auerbunch/Dyno_15_Oct_07.JPG
Old Feb 23, 2008 | 03:35 AM
socmguy's Avatar
Restricted User
It's not always about peak HP #s.
It's more about average hp #s.
Old Feb 23, 2008 | 11:59 AM
kingsey's Avatar
I've done some searching what one do you think makes better average HP out of an A4
Old Feb 23, 2008 | 12:02 PM
PREDATOR-Z's Avatar
This one 224/224 .609/.581 111+3 LSA
Old Feb 23, 2008 | 01:02 PM
kingsey's Avatar
so higher lift equals more HP and TQ?
Old Feb 23, 2008 | 01:06 PM
davered00ss's Avatar
Moderator
TR224 is a better cam.
Old Feb 24, 2008 | 07:56 AM
PREDATOR-Z's Avatar
Yse and it is not only the lift it is the lobe and valve events.
Old Feb 24, 2008 | 12:37 PM
kingsey's Avatar
The buddy who is doing the work said go with the one with the smaller lift as the higher lift can't give you that much more HP. the lobes are very close and the lower lift is easier on the springs and lifters.
Old Feb 24, 2008 | 01:24 PM
CarnivorWS.6-01's Avatar
I have the 224R. I love it. Go with dual springs. I got Patriot golds delivered from a LS1 tech vendor for under $240.00. It will all be in the tune when all is said and done. I have no input for an A4
Old Feb 24, 2008 | 06:14 PM
kingsey's Avatar
Think im going to go with the TR224 on a 112lsa
Old Feb 24, 2008 | 06:19 PM
Ryan02SS's Avatar
Can't go wrong with that. Add some heads and you'll get power in my sig numbers.
Old Feb 24, 2008 | 06:33 PM
Moderator
430/403 mods in sig
Old Feb 24, 2008 | 11:10 PM
z28ss4me's Avatar
Originally Posted by davered00ss
430/403 mods in sig
Nice numbers...I'm thinkin; about AFR 205's myself, but didn't figured I'd get much over 400 hp with a 12 bolt. Are you runnin a 12 bolt rear with yours?
