Patrick G cam results
Old Feb 24, 2008 | 07:45 PM
M-Ten's Avatar
Originally Posted by cws T/A
Looks like the power was still climbing , why did they shut it down at 6k ?
yeah it was climbing pretty steadily!!
Old Feb 24, 2008 | 08:09 PM
chrs1313's Avatar
nice cam choice and results...
Old Feb 24, 2008 | 08:14 PM
SidewayzOZ's Avatar
Ditto, where did it peak? Looks like it wasn't finished.
Old Feb 24, 2008 | 08:47 PM
PWORLDSTANG's Avatar
Congrats bro!
Sure 400RWHP would've been nice, but those numbers are still on par. That's a nice power gain from where you were before.
.... And your car sounds soooo much meaner!
Old Feb 24, 2008 | 09:57 PM
mgcook's Avatar
you had at least another 500-700 RPM left in it before power dropped off. i bet you would have made over 400 if it was revved out more.
Old Feb 24, 2008 | 10:54 PM
rocksws6's Avatar
Yeah I have the same cam and my favorite part of the hp curve is that its almost flat from 6k to 6750 it holds great on top end and still has great midrange. Here's my graph to compare. No UD pulley for me. Other than that I think everything else is the same.
File Type: pdf
Old Feb 25, 2008 | 12:48 AM
BayAreaSS's Avatar
We did take it to 6500 on one run and it did not pick up any power. The hp stayed the same all the way to the limiter. After i get the new clutch and break it in might get back on the dyno and see if anything changes. Just to make sure the clutch was not robbing me of any power.
Old Feb 25, 2008 | 12:50 AM
BayAreaSS's Avatar
Our graphs look damn near identical
For some reason i feel like i will be able to hit 400 next time. But it really isn't that important. As long as the power is too low and it runs good than im happy
Old Feb 25, 2008 | 01:11 AM
rocksws6's Avatar
^That's a great cam patrick specd for us. If you get the chance look at my thread in the kills section. You'll get to see it in action.
Old Feb 25, 2008 | 01:15 AM
BayAreaSS's Avatar
Yea i really like this cam. At about 4500-4700 it feels like a 50 shot of spray. It just takes off!
And i already checked out the vids. You run strong. You'll see some kills from me in the future
Old Feb 25, 2008 | 01:29 AM
BuBbABFP's Avatar
Very nice numbers mang!! I bet it rips!
Old Feb 25, 2008 | 01:35 AM
  #32
misho911's Avatar
VERY GOOD no's...
what is the exhaust you installed???
Old Feb 25, 2008 | 02:25 AM
  #33
PREDATOR-Z's Avatar
Nice, look at that trq at 3K rpm.
You kinda cut it off early though 6K, that cam hasn't even reached peak yet, you would have sqeezed a few more ponies out.
Did you degree the cam?
Old Feb 25, 2008 | 02:51 PM
  #34
BuBbABFP's Avatar
It seems that you can hold that flat power band at top for another 300-400 RPM.
Old Feb 25, 2008 | 06:14 PM
  #35
BayAreaSS's Avatar
Originally Posted by misho911
VERY GOOD no's...
I have pacesetter LT's 3" x-pipe true duals with dynomax bullets dumped
Yea i really like the torque of this cam. We took it to 6500 on a run and it peaked at 6k every time and held the same power to the limiter. No i did not degree the cam
When i race the car i will probably shift at about 6200 because it still makes the same hp. I will re dyno the car after i get the new clutch and break it in. I will make sure i have a graph that shows you guys the 6500 pull. I also want to make another pull because my clutch is hurt and i would like to make sure that didn't rob me of a few ponies.
So do you have all the parts for your h/c package?
Old Feb 25, 2008 | 06:58 PM
  #36
WickEdSix98's Avatar
Looks like if you would have pulled it to 6200-6400 you would have gotten a few more ponies because it never peaked on the graph. Congrats though. A small tip as well, at the race track, to run fast you don't shift at the peak hp. You need to rev past peak so that it will fall back into the power and recover better on the shifts.
Old Feb 25, 2008 | 09:16 PM
  #37
BayAreaSS's Avatar
Yea i know i want to go past the peak so it falls back into the sweet spot after i shift.
I will have to get on the dyno after the new clutch and run it to 6500 for you guys
Old Feb 25, 2008 | 09:18 PM
  #38
M-Ten's Avatar
Did you fit your 3" over the axle?
Old Feb 25, 2008 | 09:44 PM
  #39
MdFormula350's Avatar
very nice gains!
I am getting something fairly similar in size a 228/232, looking for similar gains as well.
well done.
Old Feb 25, 2008 | 09:45 PM
  #40
BayAreaSS's Avatar
Originally Posted by MdFormula350
very nice gains!
well done.
thanks man. I also looked at a 228/232 when i was searching for a cam. There has been good results with that grind
