Trick Flow Top End Kit
Old Feb 25, 2008 | 05:13 PM
DutchmanSS's Avatar
Former Vendor
Default Trick Flow Top End Kit
I was wondering if anybody is running the 485hp package? How do you like it, and would you go with it again if you had to do it over ?
Old Feb 25, 2008 | 07:18 PM
AINT SKEERED's Avatar
Just search Trickflow packages and it will give you a bunch of threads to read. There are a few people who run them but most get heads with a Vengeance racing Cam. I hear that the packages are pretty good though. Just depends on how hot of a cam you want.
Old Feb 25, 2008 | 08:29 PM
allthrotle's Avatar
Im running the trick flow stg 3 cam but, I ran out of money so I couldnt buy the heads, so I ended up using the patriot stg 2 heads. I personally like all of the trick flow products. Just my 2cents.
Old Mar 1, 2008 | 08:18 PM
z28misfit's Avatar
that stock 10bolt rear isn't gonna like you if you take it too the track,not sure what you have though, (camaro, vette, gto) you don't have a signature at all. I've been thinking about these heads as well, problem is my money is tight at the moment. The TFS heads look promising though.
Old Mar 2, 2008 | 04:58 PM
z28misfit's Avatar
never heard anything bad about them yet, although don't know what anyone could say bad about them.
Old Mar 2, 2008 | 05:42 PM
m8w6r77's Avatar
i am getting the 515hp package pretty soon. the only bad thing that i have heard is that you have to run aftermarket rockers. which is not a problem with package b/c it comes with h/s rockers.
Old Mar 2, 2008 | 05:57 PM
z28misfit's Avatar
all in all , the H/C packages seem to be priced half decent. it's ashame I don't need a cam, this would be a pretty much a no brainer decision. As long as you don't want a cam bigger than a 228 the 515hp you mentioned,this is a pretty tempting buy.
Old Mar 2, 2008 | 06:17 PM
m8w6r77's Avatar
i know it is. i have been eying it for a while now. it also says to use the ls6 or fast intake. which i am thinking of running the new Weiand with that setup on my lq4.
Old Mar 2, 2008 | 06:41 PM
brandon2000z's Avatar
where do you find those packages at? who sells them i looked at tfs' webpage and nothing
Old Mar 3, 2008 | 07:40 AM
z28misfit's Avatar
summit has them
Old Mar 3, 2008 | 02:11 PM
TrickFlowTech's Avatar
LS1Tech Sponsor
Here is a link for our list of dealers.
http://www.trickflow.com/dealers/dealers.asp
__________________
Old Mar 3, 2008 | 02:14 PM
LS1Tech Sponsor
You can still get everything needed. Just have the dealer remove the cam from the package.
__________________
Old Mar 3, 2008 | 03:20 PM
z28misfit's Avatar
well in that case i might have to look into this. I was getting ready to start pricing everything out individually.
Old Mar 3, 2008 | 05:12 PM
DutchmanSS's Avatar
Former Vendor
I am looking to purchase this package probably late summer. i want to do the bolt-ons first.
Old Mar 3, 2008 | 06:23 PM
DutchmanSS's Avatar
Former Vendor
I got a 2002 Camaro SS
Old Mar 3, 2008 | 07:06 PM
z28misfit's Avatar
these heads offer better piston to valve clearance even with the valves being 2.04/1.57 correct? or am I wrong? I know I ultimately would have to check the clearance myself but would kinda like a heads up before hand. Cam is in signature, even though LG doesn't give out specs, so I guess that almost does no good.LOL!!!
Old Mar 3, 2008 | 07:09 PM
z28misfit's Avatar
Are you Andy Trupe? The only reason I ask is you now have a signature and you have the same exact cars that a kid I know had. Well at least the years, don't know what color your cars were.
Old Mar 4, 2008 | 09:02 AM
LS1Tech Sponsor
You are correct, they do offer better piston to valve clearance. Without knowing the specs on the cam I will always tell you to check your clearances.
__________________
Old Mar 4, 2008 | 07:23 PM
z28misfit's Avatar
Thanks, that's what I really wanted too know.
Old Mar 5, 2008 | 12:42 PM
LS1Tech Sponsor
Your welcome.
__________________
