Head & Main bolts - Fel-Pro vs. ARP
i do not believe felpro makes head and main bolts... they do make head gaskets...
ARP all the way... settle for nothing but the best on ur High HP engine. And go with studs for more strength
Double-checking...
Fel-Pro box (2)
Head bolt set ES72173
Future number 21-1167
GM Products 1997-00 292 (4.8L)En, VIN V; 323 (5.3L) Eng VIN T; 350 (5.7L) Eng VIN G; 364 (6.0L) Eng VIN U
Qty Part No. Description
8 91330 Head bolts
2 91333 Head bolts
5 91345 Head bolts
...<boring stuff omitted>...
c1999 Fel- Pro Gaskets, Federal-Mogul Corporation
...<more boring stuff omitted>...
Fel-Pro box (2)
8 91330 Head bolts
2 91333 Head bolts
5 91345 Head bolts
Fel-Pro is still torque to yield...ARP is not...in fact, I believe Fel-Pro is buying them from whoever makes them for GM and reselling...
So stock is TTY, and Fel-Pro is then. ARP is not? I thought TTY was a good thing for secure hold-down.
I'm a little behind on the TTY vs. non-TTY issue.
tty is a PITA to install (takes a angle torque gauge to do it right) and they CAN NOT be reused....plus they tend to break when your installing them (had oil pan bolts do this)....
non-tty (ARP) just get installed with a torque wrench and can be reused again.....
in truth, the best is studs. They make install of heads much easier (they act as a guide), are stronger, and you actually get a better torque reading because your not dealing with threads in the block durring torquing.....
get the ARPs 12-point nut head and main studs, and your engine will be almost nuke proof....
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
