Oil Pressure problems!
Stock bottom end 6 liter. ZERO oil pressure, not even a little bit, even after priming the pump, and cranking without coil packs plugged in.
-New GM LS6 oil pump
-Barbell is installed correctly in the rear
-O-ring is new at the pump
-I used an LS pick-up, and pan (clearance shouldn't be an issue).
-Bypass valve in the pump is closed
-Pulled the front cover off. Pulled the plate off the pump, its full of oil.
-Pulled the valve cover on the drivers side, bone dry.
What is left to look at? I'm stuck and frustrated!
-Mike
Is your oil pressure gauge good?
Try filling the oil filter with oil then put it back.
Check your o-ring, it could be punched during install.
Prime it again.
Last, it could be your pump. You may try another pump.
Prime it again.
Cranked with no coils for probably 30 seconds. I always fill the filter with oil before I put it back on.
I'm getting ready to change to another pump. This is becoming a real pain in the ***.
I don't know what to do.
Any ideas?
