Low oil pressure, WTF??
First thing I did was change the oil/filter and pulled the valve covers off and had a look. Everything looked OK so I buttoned it up and drove the car a little bit. It sounds fine and isnt skipping a beat at all. No ticking or stange sounds. I am suspecting either a bad pressure sending unit/gauge or a slowly failing oil pump. I almost 99% sure its not a rod bearing or anything like that. Once I get a mechanical gauge on it I can narrow it down a little more.
What do you guys think? This **** pisses me off.
